Re: CRT TVs
Yes, I think they know that as I've repeated it (to them and many other people) probably over a billion times before. It's just that they have quite a few other friends who believe that newer is always better (the worst case being, this one couple, who thinks appliances need to be changed every 5 years, because they are bound to break). So sometimes they do feel a bit pressured to renovate things around the house. But in general, I've been able to convince them not to.
The HP OfficeJet Pro printer line says hello too.
As far as I know, the 2007-2013 models (and possibly current ones too) had this issue where a cheap thin plastic gear on the main paper feed/drive drive axle would break. This would make the printer throw an error and render it completely inoperable. I've seen a lot of those HP printers on eBay / CL described as "make grinding noises when trying to print". The fix is to remove that gear, drill through the metal drive axle, and put a metal insert.... that is, only if you don't mind taking the whole printer apart - down to the smallest detail to get to that part.
You're right, it's only a matter of time. But that WHEN is when I move to my own place some day... SOME DAY...
My KFC Smile CRT monitor has Jamicon, G-Luxon, and Elite caps in it. The picture does take a long time to "fill" the screen now (a possible indication that some of the caps may be starting to fail). But it still works. For a nearly 18 year-old monitor (made in 1998), I can totally forgive its flaws. I am actually more worried about the (formerly) beige plastic crumbling apart and the tube falling through
. It is dark yellow now.
That will do it.
There's actually more danger from the primary bulk cap still being charged. But that really applies to any SMPS.
For just looking at it? - Nope. Zilch. None.
Cleaning? - Hardly any, especially if the TV is unplugged and has been off for an hour or more.
Pulling the boards? - No risk if you discharge the anode and primary bulk cap. The B+ filer cap usually self-discharges by itself too. But B+ is typically 120V DC, which even with sweaty hands won't hurt too much.
Some do, some don't. But either way, many of them do self-discharge relatively quickly. That static "sparking" noise you hear when you turn the TV OFF is the anode discharging. Of course the tube could still have some residual charge, but it's unlikely that it will get you - not unless you stick your hand under the anode cap anyways.
Nope. Shadow mask flat tubes became rather popular in the early 2000's - especially Samsung tubes. Those tubs are actually still slightly curved on the inside, but you can't really tell by looking at the image. The only way you might be able to tell is from the reflection of the screen: if you see two reflections - one from anti-reflective coating and another "curved" one on top of it, you're probably looking at a shadow mask.
. It is dark yellow now.That will do it.
I can't reach the bulk cap to check for voltage without removing the board. Would rubber gloves be good enough to pull that board out to discharge it?
, Singapore, and Mexico only (IIRC). I think only later in the 90's when Samsung and LG became more popular that Korean CRTs like Samsung emerged on the market. The only Chinese manufacturer I know made CRTs is Chunghwa (the same one that now makes cheap LCDs). But from what I understand, they came very late into the CRT game, which is why we don't really see their tubes anywhere. Had CRT technology remained popular today, I'm sure we would have seen a lot more Chinese brands.
