CRT TVs
Re: CRT TVs
I bought this refurbished Toshiba 32JW9UA about 7 years ago and still works fine. Although it's difficult to show in a photograph, it shows a picture that amazes me every time I turn it on.
Although I always run it in SD mode, I can clearly notice when the source is HD.
The screen flickers too much in HD mode.Comment
Re: CRT TVs
I only have one CRT monitor, but it's one of the few good CRT computer monitors I've seen. Most of the CRT monitors made after 1997 that I've seen had a blurry picture, along with some other issues. Only one whined, but it was obviously broken. My monitor buzzes, which is something I've never seen before.
I still remember the Compaq V55. That was the only CRT monitor that could actually be called Can't Read This. They all had a blurry picture from the factory, and changing the computer's video card affected how blurry the picture was. At best, it was barely usable.Comment
Re: CRT TVs
CRT TVs are given away free on a daily basis on my local kijiji. Everything from expensive Sony 36 inch WEGAs (200 pounds?) to other brand names like Panasonic, JVC, Sharp, etc.
Most people just want them out of their house to make way for the new thin TV and reclaim some space in their homes.
RPTV (rear projection) are also commonly found for free. Everything up to 60 inches and most in working condition.
People, however, have totally unreasonable expectations in selling their thin LCD/LED TVs. Broken LCDs are advertised for $150 to $200. Asking prices for working LCD/LED TVs are more expensive than what you can buy on sale.--- begin sig file ---
--- end sig file ---Comment
Re: CRT TVs
Can't seem to get the zenith to do what i want. It didn't come with a remote. I'm trying to use the antenna, but I can't get to it using the buttons on the tv. Channel up or down cycles it to "CH 60" or "AUX" not sure why it won't change the actual channel. Tried 8 different remotes in the house and none of them do anything. Aux works through composite but that's not what I want to useComment
Re: CRT TVs
You'll need the remote to reprogram the channels. If you search for the model number on ebay and add remote to it you should be able to find one. I had to get a new remote for a vcr last year and it came up for about $30. The originals around here somewhere but I quit trying to find it after a while.sigpicThe Sky Is FallingComment
Re: CRT TVs
$30, wow! That's steep. A lot more than the VCR is worth.Comment
Re: CRT TVs
it's by voltage.
you can get something 25 years old, any 160v+ caps will be dry - the rest usually o.k.Comment
Re: CRT TVs
My old Samsung SyncMaster 19" LCD was 10 years old before I re-capped and sold it a couple of weeks ago (only due to replacing it with another monitor with inbuilt speakers). The original caps were CapXons, but surprisingly, they were all still perfectly fine.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Re: CRT TVs
I used to watch Austar satellite pay TV on it, now I just watch FTA Digital TV via a STB.
Sort of amusing to see that EMPR have parts for it. Something like $250AUD for a main board and $1200AUD for a CRT. as much as I still enjoy the TV, unlikely that I would spend anything like that on it.Last edited by rievax_60; 08-16-2015, 07:56 AM.Comment
Re: CRT TVs
Here are some pictures of the Trinitron. It looks surprisingly clear with S-Video, but I have an RGB cable coming in the mail, which I'm guessing will look better than S-Video, mainly because S-Video is limited to 1024x768Comment
Re: CRT TVs
they are used on the gun circuits for example.
so it's probably just the higher voltage causing more internal stress and heating.Comment
Re: CRT TVs
This 15 years old Panasonic Quintrix 32" not only refuses to die, but stubbornly insists in working perfectly OK.
The dinosaur is so Jurassic that it lacks VGA (not to mention HDMI) headers, so I had to connect the HTPC at left thru a Logilink VG0003 PC to TV converter.
I should have replaced it long ago, but out of mere lazyness (the thing weighs as much as a frigging Tiger tank, you need two strong guys, and preferably three, to carry it) it keeps soldiering on.
Re: CRT TVs
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: CRT TVs
In my opinion, CRTs are awesome for video and gaming as long as you crank the refresh rate up.
LCDs are better for office\internet or such though."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
by cmonkeyTurned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
Anyone seen this before?
Thinking about it some more, it happened...05-19-2023, 01:01 PM -
by handsworthJust wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
by rumi409 Hi,
I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...1 Photo -
by Mustafa85Hi guys,
Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics -
by ivtecHi folks i need some help from the electronics pros on a small audio amp for my old lcd tv that sound is too low on the speakers despite to be on the max volume, i know the issue is on the main board , the only solution is to buy a new board but i don't want to shell out 50 bucks for a board . I have seen in Utube some home made audio amps but i'm weary about those projects, i 've seen a audio buit with an STK audio amp ,. I don't have STK4142, i have STK4273, my question if this is not fake and works can i do it with STK4273 instead of STK4142? thanks https://www.youtube.com/watch?v=BcTZS5Y...02-04-2024, 10:42 AM
- Loading...
