Beginner: Need advice on ATX PSU > Bench PSU...
+ More Options
Posts
  • Widget
    • Aug 2015
    • 74
    Hey guys,
    new here and to electronics, was hoping for some feedback on my current project.
    I have an old Antec 350w PSU sitting ehre and I want to turn it into a PSU that I can use for Electrolysis (rust removal). I have a general idea of what to do, but a few things seem to boggle me.
    First, a few pics..
    There's a bulging cap I was going to replace. The caps used are 'Fuhjyyu' brand.. which I read were rubbish.
    Question: Do I need to keep the uF the same or can I go higher?
    https://youtu.be/z2oSFpKh_Uw?list=FL...qhwKriX-qQLpoA
    http://jumperone.com/2012/12/convert...supply-faq/#Q2
    This is the one I'm (sort of) following. Though I wasn't planning on using the 3.3v.. probably just use the 5v and 12v connected to binding posts.
    As for the dummy load, that's where I'm having some issues with. A couple of options I'm looking at are
    1x led on the 5v (standby)
    or
    Using the psu fan (as suggested by a member in another forum), connecting it directly to a 12v wire and ground.
    However, I'm wanting to use LED(s).. but.. I'm still a little uncertain on Resistors.
    I had a look at the datasheet for some LEDs I'm considering getting, but am having trouble figuring out what specs/requirements they are..
    http://pdf1.alldatasheet.com/datashe...GHT/L53HD.html
    i think the above datasheet has details for all 3x LED's below ?
    Kingbright L-53HD - 25mA max? (0.025 Amp)
    Kingbright L-53ND - 30mA max? (0.030 Amp)
    Kingbright L-53GD - 25mA max? (0.025 Amp)
    According to RSOnline (where I'm looking to get from), they say
    RED forward V = 2.25 V
    Orange forward v = 2.05 V
    Green forward V = 2 V
    So, say I put the RED LED on the +5v Standby and I want to run 20mA (0.020 amps) through it.
    RED LED has 2.25fV drop ? = 2.75v ?
    R = V / I
    R = 2.75 / 0.020
    R = 135.5ohms ? will limit current to 20mA ? = ok to use on that LED ?
    (orange R = 147.5)
    (Green R = 150)
    These are 133ohms,
    http://au.rs-online.com/web/p/throug...stors/6833014/
    which means
    I = V / R
    I = 2.75v / 133
    I = 0.0206... ?
    Is that right?
    If so, that would mean the 133ohm resistors would still be ok for the orange and green LEDs (about 0.022A) ?
    Appreciated any and all feedback
    Great Sage ι½Šε€©ε€§θ–
    • 31181
    Re: Beginner: Need advice on ATX PSU > Bench PSU...
    led calculator
    http://led.linear1.org/1led.wiz
      Do you know the spec of the expected minimum load for this power supply is for it to regulate properly?
      • Widget
        • Aug 2015
        • 74
        Thanks stj . I had a look, and it's giving me a different resistance than my calculations.. is there something wrong with how I calculated the resistance from the above post?
        Hi budm ... I'm not sure :/. Do you mean minimum load for the LED setup? or the amount (minimum) load connecting to the psu once complete?
        At this stage, I hadn't planned to use it as a lab PSU for powering other electronics, rather a bit of a hands-on learning experience to make a power source for rust removal (electrolysis)
        • fzabkar
          • Mar 2009
          • 772
          For electrolysis you need a current source, not a voltage source.
            • Jul 2011
            • 6060
            Originally posted by Widget
            Hey guys,
            [URL=http://s998.photobucket.com/user/Widget1983/media/Electronics/IMG_20150725_205012_zpsj7grc5jy.jpg.html][IMG]http://i998.photobucket.com/albums/af101/Widget1983/Electronics
            [url]http://pdf1.alldatasheet.com/datasheet-pdf
            Kingbright L-53GD - 25mA max? (0.025g Amp)
            R = V / I
            R = 2.75 / 0.020
            (orange R = 147.5)
            (Green R = 150)
            These are 133ohms,
            which means
            I = V / R
            I = 2.75v / 133
            I = 0.0206... ?
            Is that right?
            If you want to be on the safe side you can use a one Kohm resistor for the voltage 3.3 to 12 volts with no problem
            You could use A 130 ohm resistor but you would be drive the LED hard and it would not last long you could use a 330 ohm resistor which would a better choice for 3.3 volts
            • Widget
              • Aug 2015
              • 74
              Thanks guys,
              fzabkar: True, I was going to use the 12v source as from what I've read, 21A was more than enough for the items/size that I want to de-rust.
              sam: not sure what you mean about the 1kohm for 3.3 to 12v?
              With the LED resistors, I was going to go with 140ohm, but I wasn't sure of how bright a higher resistor would make the LED, so I went for closer to max.
              I've ordered some LEDs/resistors so I might use some alligator clips to have a play when they get here. hopefully I ordered the correct ones...
              • mariushm
                • May 2011
                • 3799
                You don't need 20mA for leds. Modern leds will be super bright even at 10 mA. Some SuperBright red leds will leave a spot of red across the room with even 5mA.
                You choose the resistor using the classic, plain, V = I x R but you have to keep in mind the forward voltage of the led which varies depending on the color.
                Red/yellow/orange leds have forward voltage of about 1.8-2.2v, green, blue, white have about 3-3.2v forward voltage
                So basically Vin - Vled = I x R ---> R = (Vin-Vled) / I
                For 10mA (0.01A) and led with 3v forward voltage and 12v input voltage you have R = (12-3)/0.01 = 9/0.01 = 900 ohm. I'd just pick a 1000 ohm resistor and be satisfied with about 8-9mA going through the led.
                The energy dissipated in the resistor will be P = I x I x R = 0.01x0.01x900 = 0.09w so a resistor rated for 0.125w will be sufficient.
                  "fzabkar: True, I was going to use the 12v source as from what I've read, 21A was more than enough for the items/size that I want to de-rust." So you need 21A of current to flow for it to work, but the amount of current depends on the load resistance but since the load resistance will vary so to maintain 21A to flow then you will need constant current source.
                  12V @21A that is a very low resistance.
                  • Mess
                    Motherboard diagnostic beginner advice
                    by Mess
                    To save you some time: the most important bits are in bold.
                    Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now πŸ˜… Briefness is for poets not me πŸ™ˆ
                    Please help!! 🎢I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎡 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                    09-12-2024, 07:02 PM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                  • Eniaro
                    Bench test a series X
                    by Eniaro
                    How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                    06-17-2025, 01:46 PM
                  • EasyGoing1
                    Shopping for a bench power supply, Advice?
                    by EasyGoing1
                    I've never owned a bench power supply before, so it's time to get one.
                    My price range is around $100, and what I'm looking for, is the knowledge from past experience. If anyone can comment on what I should be looking for in terms of features and capabilities, or what I should be looking for in terms of β€œgotcha's” ... Would be much appreciated.
                    I do remember reading somewhere, that some power supplies will use pulse with modulation, and I honestly don't know if that's really common problem or not or even how I would identify a power supply...
                    09-29-2020, 03:38 AM
                  • Jidis
                    Need T-Con Advice (Vizio P602ui-B3)
                    by Jidis
                    I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                    He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                    09-22-2025, 05:10 PM
