Shopping for a bench power supply, Advice?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I've never owned a bench power supply before, so it's time to get one.
    My price range is around $100, and what I'm looking for, is the knowledge from past experience. If anyone can comment on what I should be looking for in terms of features and capabilities, or what I should be looking for in terms of “gotcha's” ... Would be much appreciated.
    I do remember reading somewhere, that some power supplies will use pulse with modulation, and I honestly don't know if that's really common problem or not or even how I would identify a power supply that does that because I would certainly want a digitally controlled power supply that outputs an analog and clean signal. And a programmable via USB sounds like fun, but is that capability truly worth the effort or is it just more “gimmicky”?
    Thank you very much for your time.
    sigpic
    • 31285
    Re: Shopping for a bench power supply, Advice?
    you need to asses your maximium voltage and current needs.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I figure 30V at 5 Amps will be plenty for my needs.
      sigpic
        • Jul 2011
        • 6070
        I will give you a recommendation if you work on LED modules I would get the 60 volt @ 5 amp you might pay a little more for it but to me it worth the extra money
        I would also recommend not getting a switching power supply version if going to test motor and the like
        I have one that is 30 volts at 10 amp I only use it for testing car stereos / car amp and LED modules ( this power supply I have already had to repair the switching power supply regulator and recapped it )
        I would recommend getting a transformer type of bench power ( you can abuse the shit of these and for most part will survive I have about 5 different voltage and or and amperages and so far I have only repaired one of because of stupid shit )
        The view points are my own if I were buying one now with the knowledge that have this is what I would buy
        I hope this helps
          • 31285
          https://www.youtube.com/user/sdgelectronics/videos
          this guy has reviewd a number of good psu's
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Don't just come up with some numbers; sit down and "what-if" different scenarios and see how your needs might change. Then, look over the list of requirements and see if any of the outliers can be eliminated ("Do I really need to have a bench supply to handle THAT particular scenario? Or, could I handle it better with some other approach??") to get you to your "what you REALLY need".
            As far as features are concerned, my favorite supplies are triple output, digitally programmable (GPIB -- old tech -- and front panel keypad). They have built-inn metering so I can set a current/voltage limit and observe how the voltage/current changes -- useful when powering up something "unknown" (or, as a cheap battery charger!).
            I also like being able to push a button and have the output inhibited -- or enabled. An on/off switch that doesn't require dicking with the present settings.
            The tougher requirement to specify is what the power transitions look like. Does it snap on/off? ramp up/down? etc. Some loads are very fussy about controlling the power supplies as they come on/go off -- expecially when you have more than one supply feeding a circuit!
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Well, I will be working with LEDs but rarely would I be needing more than 19 volts, and typical circuits that I work with are about 9 volts.
              This reminded me that I forgot to ask in my OP... what is the difference between the switching types and the non-switching types? Do the switching types use PWM or something? Is the output wave noisier?
              I hope this helps
              Except that I can't quite tell which PS you're recommending unless its a 60V at 5A NON-Switching type?
              sigpic
                • Jul 2011
                • 6070
                Yes this is the non switching type of power supply
                One note if you decide to buy this one make sure that it linear power supply not a switching power supply
                https://www.ebay.com/itm/30V-60V-10A...r=631736358588
                Because when I went looking for one I saw a lot of switching power supply versions and very few linear ones you find a few of them in the 30 volt version but not in the 60 version
                If you do decide to buy a switching power supply version I highly recommended that after you run it over 24 hours to make sure that you have no issues then recap the boards if the capacitors are not a brand name you recognize I recommend highly torture test the hell out of it short the leads together to make sure it can handle the amperage load ( before you recap the boards )
                In a switching power supply type they use a switching power supply regulator ic of some sort some switching power supply regulator are better than other the problem is you do not any idea what type they use until you get the power supply and open and find what ic chip has been used
                  • Jul 2011
                  • 6070
                  Here is the post about the bench switching power supply
                  https://www.badcaps.net/forum/showthread.php?t=72557
                    • 31285
                    btw, what's the price limit??
                    are we looking for a used HP, cheap chinese thing for <$100,
                    or a new linear job like from Rigol. for closer to $400??
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8710
                      Thought question of the day: Some linear adjustable power supplies have a relay switch to reduce power consumption.
                      Can these be called switching power supplies?
                      • Harvey
                        • Apr 2007
                        • 264
                        Mine has a big red switch on the front....https://www.youtube.com/watch?v=p2EMnCi1RFI
                          • 31285
                          the relay he's talking about changes transformer windings to reduce the voltage drop across the transistors.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            I have a question: How can a power supply be both linear AND switching?
                            For example: https://www.amazon.com/Kungber-Adjus.../dp/B08DJ1S7J5
                            sigpic
                              • Jul 2011
                              • 6070
                              From the picture that they have it is a switching power supply
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8710
                                probably using the term incorrectly, this is a switching supply. Linear is probably referring to the ability to linearly select voltage and current instead of having to go to discretely choose specific voltages (which is "adjustable" too.)
                                Or it could refer to a dual stage regulator... of which the postulation also qualifies.
                                  • 31285
                                  it could be a fixed switching psu instead of the main transformer, but still feeding into a variable linear regulator for the final output.
                                  that would reduce weight and cost.
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    OK, so then at least this confirms that a power supply can't truly be both - fundamentally that is ... I was hoping I wasn't missing something.
                                    sigpic
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                      03-31-2024, 02:12 PM
                                    • shamsudeen
                                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                      by shamsudeen
                                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                      07-19-2025, 07:14 AM
                                    • rabsonnjala
                                      LENOVO IDEAPAD 100 works only on bench power supply
                                      by rabsonnjala
                                      Hie I have a Lenovo laptop
                                      Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                      it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                      below are my readings
                                      with the original charger only
                                      JBATT1
                                      PIN1 0.22V
                                      PIN2 0.22V
                                      PIN3 0.45V
                                      PIN4 0.45V
                                      PIN5 O.43V
                                      PIN6 0V
                                      PIN7 GND
                                      PIN8...
                                      11-20-2021, 08:32 AM
                                      07-01-2024, 06:34 AM
