Using a pos 12v lead as a "ground cut" (motorcycle)
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    I wanted to ask you guys a general question about a turn signal buzzer circuit I am trying to finish wiring on my motorcycle.
    I have the buzzer working (using two diodes, and a piezo buzzer). However, I did want to add in this functionality where the buzzer would not engage when the brakes are on (brake light switch on).
    I've read some conflicting information about using the positive lead from the switched side of my brake light to create a "ground cut". The way suggested is to simple wire the negative lead of the piezo buzzer to the positive switched lead of the brake light. It doesn't make sense to me, but the idea is, when the 12v line to the brake light is 12v+, then the buzzer's ground will be cut.
    Would this work , regardless of other wiring on the bike? I've read at least one anecdote from someone saying they had trouble with this. Said it burned out his brake light switch!
    Thanks for any ideas, and a diagram of what I am talking about is attached.
    http://www.rattlebars.com/mtz/brk-4way-buzzer-diode.gif
    Re: Using a pos 12v lead as a "ground cut" (motorcycle)
    What is that GREEN/YELLOW BRAKE LIGHT wire connected to exactly? The lamp filament Voltage supply line?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      bud,
      that is the way i understand it, yes. they are saying to connect the negative lead from the piezo , to the positive (switched) lead going to the brake light.
        OK, if that is the way the brake lamp is connected as shown in my notes, then that will work.
        • tucocaps
          • Apr 2013
          • 331
          • United Stated
          thanks bud! that worked. I have another 12 volt cycle related question I'll be posting. Hopefully, you can help me out again. Really appreciate it.
          • yayayee
            ASUS GU502GV not powering on - 1285A hot
            by yayayee
            I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
            So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
            I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
            01-08-2024, 11:04 PM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
          • barry101
            Apple 820-3662 VCore shorted to ground.
            by barry101
            Hi, Would appreciate some help.
            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
            Get charger light but no fan spin or chime. No liquid damage.
            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
            06-24-2025, 07:34 AM
          • Chaks
            Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
            by Chaks
            TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
            The specs says ...
            High antenna efficiency 868MHz ISM Band
            5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
            The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
            1. Should I Fix it with a glue.
            2. Should I fix it with a double side adhesive tape
            3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
            12-09-2024, 11:06 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
