substitute for antenna 300 ohms to 75 connection.
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i'd like your opinion on this project i made for my roof top antenna,to substitute the matching transformer.
    first my Antenna rotator broke so i took it down and fixed it,it had some bolts that fell off then i had to take out the antenna 300 ohms to 75 ohms matching transformer,which broke upon unbolting it witch was bad luck,now i have no matching balloon an the worst part nowhere to buy it ,use to get stuff near here from Radio Shack which closed ,
    i have also installed a SVA15PRSM distribution Amp near the antenna and a 12v SVPI ,these items were installed before, but inside the house closer to the receiver.
    now story short,since i did not have the matching transformer ,i did not want to go by without tv i made a straight connection with coaxial cable ,took out the F connector and striped the coaxial wire connected ground wire to one side and the middle wire to the other, and for my surprise i never had so many chan and so good reception,but someone suggested me, due to water getting inside the wires to get a outdoor matching transformer.
    well made this strait wire to connect from the antenna to the amp
    as you see i cut 2 pieces of thin ground wire and connected and soldered an F type connector that i cut from type F cable connectors,
    what you think about this? will it work?i know i should go up there and try! but up there are 50 feet high and no easy access and i'm not young anymore, so will this work at least same way i have now? thanks
    http://postimg.org/image/d161lt343/ef75894e/
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: substitute for antenna 300 ohms to 75 connection.
    Could you not just use red high temp silicon to seal the end of the cable where you stripped the coax? I say red silicon because it hardens better than the other silicon. Of course you might want it to be flexible if there is stress being put on it. This way you would illuminating one connection and what you have now seems to work fine.
    • ivtec
      • Dec 2008
      • 1967
      Thanks keeney123; that's a great idea, so i don't have to mess up with my good reception, i went from 34 chan to 60 chan,
      • R_J
        • Jun 2012
        • 9622
        one of these places might have one.
        http://www.homedepot.com/p/Channel-M...4444/203763061
        http://www.lowes.com/pd_302829-63374...ductId=3724168
        http://www.bestbuy.com/site/channel-...&skuId=3980063
        • ivtec
          • Dec 2008
          • 1967
          kenney123 you're talking about this?
          http://www.amazon.com/Permatex-81160...01VD2Y1J5BRQD2
          • ivtec
            • Dec 2008
            • 1967
            Hi guys for someone out there that don't know better,don't waist money on matching balloons that end up failing very often,as mine did just do as i did, see pic,and add silicon to the striped ends,it will give you better signal and more chan,i tried this with and without balloon,and result without balloon you get better.
            http://postimg.org/image/osp3l70qh/e9c3dc75/
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Yes that is the correct one I was talking about. They are different manufacturers but that is the one I found the cheapest.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Evidently the gain of the modern TV does not require antenna matching.
                • ivtec
                  • Dec 2008
                  • 1967
                  I have people telling me that this way without matching ballun, only working with half an antenna, one side is grounded out by the coax shield.
                  this maybe true for some install,for my set up,it maybe better for signal since chan are fairly strong even without amp,i know for example on chamn 38 i use to get signal go low if i put a stronger amp 24DB in place of the 15DB, SVA15PRSM
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    There is nothing wrong about using a monopole antenna. Cheap typical TV type baluns aren't tuned very well and have signal loss at higher frequencies (uhf).
                    • narf
                      Epson EB-U42 projector / Caps with 0.7 ohms ?!
                      by narf
                      hi all,
                      first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                      i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                      what i've found so far:
                      - the PSU does its job and supplies 12V to the mainboard via the connector.
                      - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                      - not far away, there's the first cap with a resistance of 0.7 ohms....
                      07-02-2024, 03:53 PM
                    • wnlewis
                      New wire for my RDE3340 Whirlpool electric range
                      by wnlewis
                      OK. I got the rocker switch figured out thanks to the good advice on this forum.
                      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                      This is a Whirlpool RDE3340 electric range.
                      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                      Where may I find parts...
                      01-08-2025, 11:21 PM
                    • SolomonMan
                      Nest Thermostat Discussion...
                      by SolomonMan
                      All,
                      I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                      The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                      Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                      At my boy's place he has a York Stellar...
                      12-11-2022, 10:54 PM
                      Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                      I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                      I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                      12-16-2023, 08:39 PM
                    • kalemaroni
                      Dell DC Brown wire
                      by kalemaroni
                      There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                      08-26-2025, 10:10 AM
