Reliable quality voltage transformer converters?
  • xboxhaxorz
    • Jan 2011
    • 196
    I always recommend a direct 220v line over a transformer, for those that do not have an available circuit breaker dont have many options
    So after looking at AMZ their transformers vary, some working great and others dying and with the high shipping cost the warranty is not really helpful
    If you have any recommendations for something that is 2475 watts it would be great
    Re: Reliable quality voltage transformer converters?
    Are you asking for a step-up, step-down, Isolation, auto-transformer? What are the requirement?
      • 31278
      2.4Kw = about 10a - that's gonna be huge.
      • xboxhaxorz
        • Jan 2011
        • 196
        Using a 220v device in USA on 120v
        I found this, not sure on its build quality
        http://www.220-electronics.com/3500-...regulator.html
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          I think he's looking for an autotransformer, no isolation required. Knowing him it's likely that he needs it for a BGA rework station.
          A working TV? How boring!
            if the load requirement is 2475W then he needs to get one with 20% headroom.
            To step up 120V to 220V with about 2500W, the input current will be at least 21A (2500W/120V = 20.833aA)!
            • xboxhaxorz
              • Jan 2011
              • 196
              Lol you know me well, yep its a customer that wants a 220v model
              They said an electrician went by and no more breakers available, so a transformer is needed
              • xboxhaxorz
                • Jan 2011
                • 196
                This is part of the reason i do not recommend transformers
                  A 120V model it will be 21A, it not going to be any less which means it is going to be NEMA 5-30 PLUG and OUTLET, so he will be better off getting 240V model to run on us 240V system which will require about 10A.
                  • xboxhaxorz
                    • Jan 2011
                    • 196
                    I am not quite clear on transformers, i know a device that is dual voltage will heat much quicker on 220v
                    If using a transformer on 120v will it heat at the same speed or will it be half
                      • 31278
                      the wattage may be wrong, my local re-balling guy has one that uses something like 20a 230v with the bottom and top heaters all on together!
                        I do not see why that will happen, it will still consume the same Wattage as long as the wiring are made for the current handling, higher current = bigger wire gauge. The heater Voltage rating also has to be correct for the operating Voltage.
                        i.e 1000W 120V heater will require larger current than the 1000W 220V heater, power consumption stays the same at 1000W but the resistance of the two heaters will not be the same.
                          • 31278
                          can we know the make & model of the unit?
                          • xboxhaxorz
                            • Jan 2011
                            • 196
                            Maybe im thinking about something different then
                            For some reason i thought using a dual voltage device on 220 would make it more powerful than using the same device on 120v, but perhaps i was thinking of using a 220v only device on 120v and it would not work at full power
                            • xboxhaxorz
                              • Jan 2011
                              • 196
                              There are many machines ranging from 600 watts to 5000+
                              • xboxhaxorz
                                • Jan 2011
                                • 196
                                I made the recommendation of using a tandem circuit breaker in order to get more room in the breaker box
                                • UserXP
                                  Transformer producing higher voltage than rated
                                  by UserXP
                                  Hello, people.
                                  i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
                                  So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
                                  09-02-2025, 12:42 AM
                                • Fernon@Repair
                                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                  by Fernon@Repair
                                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                  VCCIO voltage ok
                                  VCCSA Voltage OK
                                  VCCPLL Voltage OK
                                  Ram Voltage ok
                                  RamVTT OK
                                  VPP 2.5 OK
                                  But No Core Voltage
                                  and i want to this vrm ic datasheet or pinout (ISL69269)
                                  anyone have this ic pinout voltages?...
                                  06-25-2025, 07:19 AM
                                  by momaka
                                  03-15-2023, 10:17 PM
                                • electron_jj
                                  Panasonic TH-L42D25A checking the PSU output voltage
                                  by electron_jj
                                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                  08-29-2021, 08:13 AM
                                • learnmore
                                  Help choosing replacement transformer for Levoit 600S SMPS
                                  by learnmore
                                  Hello Community,
                                  I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                  Peace
                                  LM...
                                  11-04-2025, 09:35 AM
