Disconnected capacitors?
  • Tom41
    • Oct 2005
    • 338
    • England
    While tidying up my server room, I put an old PSU into a box containing the CPU boards from my old server, and pushed it down hard until it went into the box . This caused one of the caps on that board to break off and another to become loose.
    It was only then that I took a closer look at the board. It doesn't seem to have ANY traces going to either of the capacitors that came loose! I checked both sides of the board, where the caps are soldered in - no traces visible.
    Is it possible they forgot to put the traces in the board silkscreen before printing it? Why put caps on the board if they're not going to be connected to anything?
    It's also possible that the board contains an extra layer inside, which the caps are connected to. I can only see the traces on the front and back of the board, but there may well be another PCB layer sandwiched between the front and back.
    Thankfully, I'll never be using those CPU boards again (unless I come across another Compaq Proliant of the same type), so it's not a big loss. Any comments?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • tvtech
    • Oct 2006
    • 48
    Re: Disconnected capacitors?
    Yep its prolly a multi-layer pcb with the ground plane and the supply plane being sandwitched in the pcb,if you hold it up to a bright light sometimes you can see the other traces in the sandwitch,I highly doubt that a manuf would put a useless component on the board.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      After all of...
      07-13-2024, 08:14 PM
    • AlexForTheWin
      Help Diagnosing ASRock Taichi X570 Motherboard
      by AlexForTheWin
      Hi all! I'm a newbie to to the forum and electronics repair in general.
      I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
      I'd very much appreciate some guidance.
      Here are the steps I've taken to diagnose the board:
      I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
      Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
      12-16-2022, 11:37 PM
    • maxim2511
      LG 55EC930V OLED - swich on swich of no screen
      by maxim2511
      My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
      Then I get an idea to take it apart and clean boards from dust.
      In side of Tv was not so bad, I take compressed air in can, and gently blow up.
      Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
      05-14-2021, 02:21 AM
