An 18V UPS...am I doomed to 6V batteries?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    After having a 1500VA UPS batteries die (Best Power Patriot Pro), I was wondering... This thing uses three 6V batteries in series, using 18V as backup (Standby UPS with AVR). 18V? Ugh. Can't use a 12V battery... or can I?
    Anyone know of some tricks to deal with an 18V standby UPS or am I stuck with buying new 6V batteries (three 6V 12Ah SLA's)?
    Re: An 18V UPS...am I doomed to 6V batteries?
    Well, depending on how the unit is designed you may be able to modify it to work on 12V. The likely issues will be the transformer windings (the transformer, if it has one, will be wound for 18V to 110/220V step-up, rather than 12V) feedback circuits (if any), and the under-voltage/battery health detection circuits.
    You might get lucky with the transformer if they design it for 12V operation too, it could have spare taps.
    But most likely, it will be a very difficult conversion and it's unlikely to be worth doing.
      • 31278
      why are 6v battery's such a problem?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        3 golf car batteries.no problem!
        • japlytic
          • Oct 2005
          • 2086
          So far, the only UPS units I have seen only use 12V batteries (or a pair of 6V batteries) - a unit requiring an odd number of 6V batteries is a bit unusual.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Well, 12 volt batteries are more common. Marine deep cycle batteries can be had fairly readily which would do fairly good as UPS batteries.
            I wonder how cheaply high capacity 6V batteries can be had...
              • 31278
              check digikey / element14 / newark etc.
              no problem.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                I might have to just get another set. It might also be the UPS toasting batteries too. I had bought a set of 3 and after one year I had battery problems - it started beeping when the battery self test failed. I'm not sure if I just had a bad batch or the UPS likes eating batteries.
                • carrzkiss
                  Cyberpower cps1500avr not charging batteries
                  by carrzkiss
                  Hello, all.
                  Cyberpower Battery Backup Unit.
                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                  Checking the voltage, it was down to 22v.
                  I quickly removed everything...
                  06-15-2024, 02:10 PM
                • howardc64
                  Where do repair shops buy MB replacement batteries?
                  by howardc64
                  Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                  Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                  BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                  07-25-2024, 10:42 AM
                • Astonished
                  Fixing the Charge Circuit of the Batteries of the DC Motor
                  by Astonished
                  Hi friends of electronics
                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                  Please help me fix this circuit.
                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                  01-28-2025, 06:24 AM
                • dbuergi
                  DIY: Modified smart charger for all types of batteries
                  by dbuergi
                  sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                  Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                  My first work was to bring my Samsung watch battery back to life with was not recognized...
                  07-18-2025, 03:17 AM
                • davidebaldini
                  UPS ruins batteries every three months
                  by davidebaldini
                  Problem description:
                  My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                  UPS model:
                  The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                  10-02-2019, 06:19 AM
