Which solderless fork terminal is needed
Tags: None
Re: Which solderless fork terminal is needed
welcome to american goods - is probably the best response.
the screws are probably imperial rather than metric so you have to look a bit harder to find the right size terminals.
let me guess, if you find a fork with the right size hole, it wont fit between the plastic divider sections - right? -
The screw is probably 6-32 or M4, the spade terminal come in lots of different fork width.
I.E.
Skinny:
http://www.mouser.com/ProductDetail/...ft2f5KdBD7I%3d
Fat:
http://www.mouser.com/ProductDetail/...ttqsX3LJmqk%3dNever stop learning
The fork part was too large, i temporarily cut half of it in order to make a connection. Thanks for the link, i was originally looking on ebay and google not mouser.Comment
by mnciks11Hello guys I'm looking for Hisense Hk570 bios , it used on till , but the board is same for laptops...
by DXseekerMOHello everyone!
Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
Symptoms:
1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
2) TV does not appear to turn on
3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
4) "Power on" terminal on Power Supply has 3.26v
5) "A13V" terminals have 12.9v
6) Stand-by test jumper on Power Supply has 12.9V
7) Optical audio jack on Main Board illuminates
8) With stand-by... -
Schematic needed (and boardview if available).
Thanks.-
Channel: Schematic Requests ONLY!
by cekconsGigabyte G1 Assasain motherboard Bios IC model needed !
Bios ic fried and I cant read the model on top.
Thanks !-
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
I decided to verify that the batteries were... - Loading...
