How to Bypass HVAC Thermostat to Test Outside Unit
  • TractorGear
    • Mar 2015
    • 40
    My neighbor has a HVAC system and the outside unit will not turn on at the thermostat. I can manually push the relay at the outside unit and it will turn on normally, so it's a low voltage problem. There is 24 VDC from the transformer at the thermostat.
    My neighbor's nephew is a retired HVAC repairman and he came by and condemn the thermostat, but after I (correctly) wired in the new one, the outside unit will still not turn on.
    Against the outside wall, next to the unit, is a "J" box where all the low voltage wiring coming out of the house are connected to the low voltage wiring going (3 ft.) to the outside unit, using electrical screw cap connectors. The J-Box is at least 20 years old, has no weatherproofing whatsoever, and we have just had some rain for the first time in about 2 years.
    The "professional" HVAC shorted wires at the outside unit and condemned the thermostat, but he never actually verified this AT the thermostat. I think there's an open, or a short, in the low-voltage wiring at this rusted, dirty J-box.
    I need to know which two wires to short at the thermostat in order to bypass it, and verify that the outside unit either does, or does not, turn on.
    If not, then a check by shorting the same wires at the J-Box should show that the problem is either before or after the J-Box in the wiring.
    Transformer(24 VDC)--->---Thermostat--->----J-Box--->----Outside Unit Relay--- Ground
    I think the problem is either just before, at, or just after the J-Box.
    What two wires do I short to simulate the thermostat turning on?
    FYI: According to the Customer Service person at Honeywell's 1-800 number, the thermostat is wired for a AC/Heat Pump with Emergency Heat as a secondary heat source. So there's 1 AC, 2 heat and a selector wire for the heat pump valve.
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: How to Bypass HVAC Thermostat to Test Outside Unit
    On t-stat sub base, you want to jump the "R" terminal to the "Y" terminal. It uses 24 volts AC from a transformer most likely in the furnace or heater. Sounds like you may have an open conductor in your low voltage cable. Most of them have extra conductors that are not always used. Easy way to test cable is to use ohm meter..kill power to heater and condensing unit outside to ensure no low voltage. disconnect all conductors on both ends..short two wires together inside i.e. red and yellow, then go outside and read with a meter to see if they show the short outside. do the same with all conductors. I bet the yellow wire connected to Y is open. If not, possible that safety in condenser is open or contactor coil is shot.
    • TractorGear
      • Mar 2015
      • 40
      Thanks that's what I needed to know. R to Y. The transformer is fastened to the wall inside the HVAC closet, and we've already measured 24 VDC present. I'll try jumping it today and report results later. Thanks again.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        The transformer typically will be inside the furnace. Typically the one fastened to the wall in the closet is for a door bell, usually 12 volts
          "and we've already measured 24 VDC present." You mean 24AC.
          • desert-rat
            • Mar 2014
            • 4103
            Its 24 vac. if jumping the r to y does not turn on the cont. look for safty switches , high pressure , low pressure , compressur ol. , a 5 min. timer , or a def. control , ect.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              As I said, a safety in the condenser open or a contactor coil that is shot. Also examine all connections made with wire nuts. The conductors in the 5 or 7 conductor cable from inside to outside and to the stat are 18 ga or smaller solid copper that can get brittle and break up inside the connector..It will look like a good connection..until you take it apart.
              • desert-rat
                • Mar 2014
                • 4103
                The door bell tran is 16 vac . Jump the red to the yellow wire , then check the cont. coil for 24 vac. If you have 24 volts and the contactor does not pull in , its bad . If you dont have 24 volts , then some thing is open some where . The common color code is , red is common , yellow is cool , white is heat , green is the fan , orange or blue is for a reversing valve on heat pumps , blue is also used for the other side of the 24 volts , but not ever thing is wired up that way .
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Red is power or "hot" side of 24 volts blue mostly is common from xnsformer if stat is power robbing..
                  • SolomonMan
                    Nest Thermostat Discussion...
                    by SolomonMan
                    All,
                    I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                    The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                    Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                    At my boy's place he has a York Stellar...
                    12-11-2022, 10:54 PM
                    Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
                    My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
                    06-22-2025, 10:23 AM
                  • ngml
                    Repair of an LG split AC system indoor unit PCB
                    by ngml
                    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                    This indicates an error in the communication between the outdoor and the indoor unit.
                    The outdoor unit is fine, so the problem is the indoor PCB.
                    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                    Does anybody have the schematics of this board,...
                    02-01-2025, 12:55 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • DrDos
                    Unit runs but no speaker output kenwood KR-6030
                    by DrDos
                    I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                    09-14-2025, 09:57 PM
