testing bulbs for quartz heater?
  • steel
    • Feb 2015
    • 8
    Hello. I have an Edenpure quartz heater that just up and quit. The elements will not light. I've removed the bulbs and ohmed them but all 3 are showing open.
    What should they ohm at? Could all 3 crap out at once?
    Thanks for any help!
    Re: testing bulbs for quartz heater?
    Pictures of the elements?
    • steel
      • Feb 2015
      • 8
      Well heck, I put it back together for now.
      I'll snap some tomorrow. I will say they look bad, badly discolored and the glass spins freely from the ceramic end caps. The bulbs are part number us001 if that helps.
      • steel
        • Feb 2015
        • 8
        [IMG][/IMG]
          It is shows open circuits then it is bad.
          • ron350
            • Feb 2014
            • 296
            Which model of Edenpure do you have?
            • steel
              • Feb 2015
              • 8
              It is the usa1000
              • ron350
                • Feb 2014
                • 296
                Well @ $32 a bulb that will be kind of a expensive repair.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  esp for a scam unit.
                  1500w of heat is the same in the end regardless whether its a coil of nichrome or a fancy bulb.
                  sounds like those are open.
                  • steel
                    • Feb 2015
                    • 8
                    Ya tell me about it. We paid 400 bucks for the thing 2 years ago after tornado damage/no power. It lasted 1 1/2 winters.
                    After spending $400 I hate to pitch it. So I'm going to go ahead and dump $85 worth of bulbs in it and hope I get a few years out of it.
                    I do love the thing, even though it is an overpriced space heater!
                    Thank you guys for easing my mind that the bulbs are in fact junk.
                    I'm not so sure all 3 ever worked, as the box was re-taped when we bought it at Home Depot.
                    Thanks again!
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Maybe it was a display unit at the store.
                      • ron350
                        • Feb 2014
                        • 296
                        Wonder if you can use light bulbs to test the heater before spending all that money?
                        • steel
                          • Feb 2015
                          • 8
                          It doesn't have a traditional light bulb socket, two prong plug is what the element has. I would assume a heating element would have high resistance, but according to my cheap harbor freight multimeter, they are open.
                          Plus the ceramic is loose from the glass tube so I'm telling myself they gotta be bad, right?
                          Well I hope anyway, I went ahead and ordered a new set. I will update soon I hope.
                            • 30977
                            we get 3kw versions of those things in europe for $20 - people still dont buy the junk.
                            the only good use for halogen heaters is to keep food hot in resturants.
                            if you want to warm a room, nothing beats a fanheater, blow the warmth around the area instead of creating a small hotspot.
                            • steel
                              • Feb 2015
                              • 8
                              Fixed!! All 3 bulbs were in fact bad. Just in case someone does a search in the future, the new bulbs checked at 26.5 ohms.
                              Thanks guys!
                              • jeffegg2
                                • Feb 2015
                                • 27
                                try to not get your fingerprints on the quartz. Clean them well and they last a lot longer. Perhaps they got dirty.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  +1
                                  more likely they are just low quality.
                                  i figured they would read low resistance but your 26.5ohms sounds about right as it has 3 in paralell.
                                    I found this video when looking for something else but this is how to use a phone charger for testing LED light bulbs
                                    Here is the website link for this project that I plan on making
                                    https://www.youtube.com/watch?v=atLERDZx0Q8
                                    But I going to use a different enclosure for this project and make it more professional looking and use safety features that was not used in this video
                                    I have some 24 volt switching power supply from my battery testing machine that I modified for a different switching power supply that is more suited for my new application and new purpose for testing BMS protection boards
                                    If can find one that I can modify the voltage output on I have a...
                                    09-09-2024, 04:47 AM
                                  • edugimeno
                                    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                    by edugimeno
                                    Hi!!
                                    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                    At a certain point, moving stuff around, I put all wires back in place and...
                                    03-24-2024, 02:31 PM
                                  • madan1
                                    Diesel heater emergency power supply / poor man's UPS
                                    by madan1
                                    Hello everyone.
                                    Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                                    12-18-2022, 08:05 PM
                                    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                    12-16-2023, 08:39 PM
                                  • sew333
                                    Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                                    by sew333
                                    Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                                    So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                                    So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                                    I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                                    06-14-2024, 07:30 AM
