How to unsolder transistor
  • Rockguy
    • Jan 2015
    • 71
    Re: How to unsolder transistor
    I should have known that since I put one lead of my meter on the tab when testing it Duh
    • Rockguy
      • Jan 2015
      • 71
      Originally posted by mmartell
      I think you'll be fine. Trace those connections then verify with your meter they are still good then flow some solder on the large pad and see what you've got.
      Where the solder remains, I have continuity with the other transistor tabs. Obviously where the copper is torn out, there is nothing. There is no damage where the legs were.
      Is the goal to try and flow new solder attaching to the old and filling the damaged area? Do I need to get a copper sheet and epoxy it in there?
        • 31094
        if the tabs are all connected, you could solder a stiff copper wire across a few.
        your really just trying to physically hold it down.
        • mmartell
          • Oct 2013
          • 3189
          Did you test the fet for short after you pulled it ? How did you know this one was short and not another one that is in parallel ?
          • Rockguy
            • Jan 2015
            • 71
            Yes, I tested it out of circuit. With that FET missing, I briefly fired up the tv and it was working so I should be good when I put this new one in. I'm planning on messing with that today if nothing comes up. I was working too much the last couple of days.
            • Rockguy
              • Jan 2015
              • 71
              That does seem like another option. Thank you for suggesting it. If flowing solder in there doesn't work as well, I can do that.
              • Rockguy
                • Jan 2015
                • 71
                As I feared, the solder will not stick to the area where the solder and everything was torn out. I'm gonna have to go with another plan.
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Can't you get solder to take where the copper is still intact? It may be enough to do the job. As I said earlier my concern is heat sinking the transistor enough through it. I wouldn't glue copper onto the area unless using highly conductive glue (both electric and heat conductive), but you could try soldering a copper shim to it and then solder the transistor tab to the copper shim.
                  • Rockguy
                    • Jan 2015
                    • 71
                    Yes, I can get solder to take where the old stuff is still there. Understood on the copper. I won't glue that in there. Your idea of soldering a copper shim sounds plausible. I got a tip from tom66 to possibly buy a tiny heatsink and attach to the top of the FET.
                      • 31094
                      thick copper wire soldered across 3 tabs (the new one in the center) should conduct the heat better thansticking a heatsink to the resin body.
                      • Rockguy
                        • Jan 2015
                        • 71
                        That would be pretty easy too I think. What kind of wire would you suggest?
                          • 31094
                          the thickest solid copper you can find.
                          got a bit of the stuff used to wire in cookers?
                          • Rockguy
                            • Jan 2015
                            • 71
                            Hmm no. I've got some house wire.
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • corrize
                              Best way to solder LVDS connector for beginner (and qfn) ?
                              by corrize
                              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                              See the test :
                              https://youtu.be/bNAzC-EvqHs?t=1767
                              With hot air from bellow the board, that's...
                              03-09-2023, 02:57 AM
                            • myth77
                              UV solder mask - high temp resistent, recomendation?
                              by myth77
                              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                              Is there any solder mask...
                              03-28-2022, 04:04 AM
                            • petemanuk
                              BGA solder balls not connecting - help pls
                              by petemanuk
                              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                              11-16-2022, 05:21 AM
                            • sircastor
                              Solder not reflowing - what am I doing wrong?
                              by sircastor
                              I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                              For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                              03-03-2024, 02:44 AM
