Threadmill Motor Control Board
  • cmia
    • Aug 2013
    • 37
    • United Kingdom
    I have a Proform CX450 which I have had for a while but never really used it.
    Recently I attempted to use it and it blows the mains fuse.
    So I have opened the lids and have had a look at the PCB, I cant see anything bad on the PCB.
    eg.
    I replace the fuse and power the unit on
    THe unit powers on and the display comes on.
    I press the green button to go and the machine attempts to turn but then stops.
    as it stops it blows a fuse.
    I replace the fuse but this time leave the motor + lead unplugged.
    and then press the green button. The threadmill looks like its working eg the incline motor works and the speed goes up.
    The motor doesnt turn as its unplugged.
    Where is the fault?
    Ideas
  • selldoor
    Slow Learner
    • 7870
    Re: Threadmill Motor Control Board
    I thought you were having a laugh - read this very current thread may give you few ideas and some ideas of what more info is required
    https://www.badcaps.net/forum/showthread.php?t=43064
      I sure do like to see the pictures of the boards in this Proform CX450.
      • cmia
        • Aug 2013
        • 37
        • United Kingdom
        Nope.. I need your assistance guys!
        PLEASE
        • selldoor
          Slow Learner
          • 7870
          Check the tread belt is not stuck to the base.
          Can you turn the motor by hand - does it turn the walk belt.
          Have you tried to power the motor with 24v from a power tool battery
          lorry battery or two car batteries.
          Have you tried anything?
          Picture of the Power supply - does that work correctly - led lights light up?
          Any error code on the information panel?
          Picture of the label on the motor
          • cmia
            • Aug 2013
            • 37
            • United Kingdom
            Hi I have checked the following
            - Belt is not stuck to the base.
            - When I walk on the thread mill the belt and it rotates freely.
            - No error codes on the control panel,
            - The PCB has a little red light on.
            - If I press the green go button it just blows the external fuse.
            I have not attempted to power the motor with two battery's in 24dcv, I can try tho!
            I have tried the additional diags,
            if I unplug the + lead of the motor from the pcb and press the green button the display panel shows it runs. I can adjust the power / speed and use the tilt motor.
            I am not sure where the power supply is.
            I had a previous fault under warranty and the manufacture replace the motor and PCB. I have two PCB's bot have the same issue.
            • selldoor
              Slow Learner
              • 7870
              Seems to be more info about on this machine.
              Someone has reverse engineered a schematic - I dont know for certain it is good
              but people have said it helped them.
              Also a picture of the board rev4 which might be useful
              I will just add stuff as I find it.
                • 30997
                maybe connect the motor with a light bulb in series.
                if the speed control varies the brightness, the motor is the problem.
                i wonder if it uses brushes.
                  The motor drive section is about the same topology as the MC70.
                  Your motor looks like this?
                  http://www.ereplacementparts.com/dri...-p-923011.html
                  • cmia
                    • Aug 2013
                    • 37
                    • United Kingdom
                    I am not sure how to plug a lightbulb in as well as the motor!
                    Thanks for the diagram, but it means very little to me..
                    but if someone wants to instruct me, I am pretty good at following instructions.
                    The motor looks similar, I have taken a picture of my motor
                    What annoys me is the machine has had so little use,
                    I am talking maybe 100 hours use in its entire life!
                    Thanks guys
                    • cmia
                      • Aug 2013
                      • 37
                      • United Kingdom
                      from what I have read the R4 board has an inbuilt psu, whilst the others have an external psu source.
                      • selldoor
                        Slow Learner
                        • 7870
                        Ok so if you follow the wires back from ACHot and ACNeut do they just go to the on/off switch
                        or to another board?
                        I will just note here the motor is 130volts DC
                          It is about the same as used in the other thread, 103VDC motor.
                          • selldoor
                            Slow Learner
                            • 7870
                            Think that should read 130vDC
                            • selldoor
                              Slow Learner
                              • 7870
                              I think he means as in attached (happy to be corrected) Just get a bulb holder
                              (inspection lamp?/ bedside light? ) put in an old type filament bulb - not led or
                              power saver cfl and connect one lead to the lead from the motor that goes to A+ and the other to the A+ connector. When you switch on the bulb will take some power away from the motor and it may run slowly - as (if) it speeds up then the bulb will dim. If the motor is faulty the bulb will just stay bright.
                              Just use this for a short test.
                                • 30997
                                that's it - a very fast test to see if the motor is shorted/stalled.
                                • cmia
                                  • Aug 2013
                                  • 37
                                  • United Kingdom
                                  Followed the wires
                                  It looks like from the mains kettle lead plug
                                  one wire which is the + goes to a breaker, the wire from the breaker goes to an EMI Filter.
                                  The - wire goes straight from the kettle lead plug to the EMI Filter.
                                  at one side of the EMI Filter I assume the insert side it has another wire, looks like a green and yellow wire. This is probably the earth wire.
                                  Now at the opposite end of the EMI filter we have two outgoing wires. These one wire goes straight to the motor, the other wire plugs into AC NET.
                                  I could try that bulb thing but I will need to go buy a bulb holder and lead.
                                  • cmia
                                    • Aug 2013
                                    • 37
                                    • United Kingdom
                                    rear picture.
                                      Did you find the wiring diagram, some how on the other thread the OP was able to provide the wiring diagram that shows how all the boards and sensors are connected together.
                                      See example of what he has.
                                      • cmia
                                        • Aug 2013
                                        • 37
                                        • United Kingdom
                                        I searched around and found some references.
                                        Not any other information yet.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Yanleb
                                          LG 60PK550 Logic Control Board EBR63450301
                                          by Yanleb
                                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                          C57: 3.30V
                                          C61:...
                                          07-20-2023, 12:38 AM
                                        • cyclones
                                          Motor control board repair
                                          by cyclones
                                          I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately...
                                          10-30-2021, 10:39 PM
                                        • Joe24
                                          Maytag Whirlpool Kenmore clothes dryer data bus
                                          by Joe24
                                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                          I've been over the board looking for...
                                          01-13-2025, 06:50 PM
