Car flicker unit ...
  • wee wee
    • Aug 2013
    • 16
    • south africa
    Hi guys,
    Just a little question for general knowledge ...
    In a car flicker unit for normal bulb, the blinking action is triggered by the bulb drawing amps.... if i got that right. So if you plug that same unit on a led light the led will just stay on because of the low amp usage.
    My question is, is it possible to fit this unit on a led by "cheating" with the amp consomation, I was thinking of if we put a resistor in parallel to the led? will it make it blink ?
    Thanx
    Cheerz
    • 30982
    Re: Car flicker unit ...
    not always.
    there are 3 types of flasher relay.
    the oldest type used a bi-metal strip with a heater on it, the current used by the bulbs heated the strip and cut the power, then it cooled and turned on again.
    and so-on.
    those are designed for a specific wattage and have problems with bad lamps or trailers.
    the newer type are electronic and the speed is fixed.
    a few of the very newest actually mess with the speed to indicate lamp failure - those are a pain.
    there is a thread here where a guy fucked one trying to fool it.
    show us the relay you have.
    • wee wee
      • Aug 2013
      • 16
      • south africa
      Hi STJ,
      I have got those two relay;
      FR-109
      Flasher (mine is electronic brand but look the exact same)
      2P, 32CP, MA x 20
      12V
      and FR-113
      Flasher
      552
      2P, 32CPmax. 6
      12V
      Ref. http://www.allproducts.com/traffic/maiding/p11.html
      http://www.allproducts.com/traffic/maiding/p11-l.jpg
      What do you think?
        • 30982
        looks like it may be the old thermal type.
        put the led bulbs in and see if it works.
        • Longbow
          • Jun 2011
          • 623
          Maybe a 4th type. Modern cars have a "bulb out" indication on the dash. The ECU looks for some expected current draw, and if the current is below what the bulb is rated for, your bulb out indicator comes on. A good place to get automotive led replacement units is superbrightleds.com. They will sell you a bleeder resistor that will keep your bulb out indicator from tripping when you install an led. But of course that defeats the purpose of using an led in the first place.
          Is it plugged in?
            • 30982
            if he has a thermal flasher, he'll need 20w resistors!!!!!
            for each bulb!!!!!!!!
            • wee wee
              • Aug 2013
              • 16
              • south africa
              I tried with a 12v 10w bulb witch triggered the unit only once ... think the bulb is too week but don't have a bigger one.
              So if I get it right I must put a resistor of 40w since the unit is for two led at the time (+the one on the dash) in parallel with my LED?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Why not just build a two transistor flip-flop flasher instead???
                • wee wee
                  • Aug 2013
                  • 16
                  • south africa
                  What is a 2 transistor flip flop flasher ?
                  • wee wee
                    • Aug 2013
                    • 16
                    • south africa
                    hoo ok will have a look.
                    This one look simple:
                    http://homemadecircuitsandschematics...istor-led.html
                    • wee wee
                      • Aug 2013
                      • 16
                      • south africa
                      so how many ohms should that resistor be?
                        • 30982
                        forget the resistor, it's a dumb idea that wil be huge and generate stupid heat.
                        it would need to simulate atleast 42w or lamps, maybe 50w including side-repeaters.
                        just use the 555 chip to drive a transistor connected to a relay.
                        or even skip the relay and use the 555 to drive a fet on a small heatsink.
                        • wee wee
                          • Aug 2013
                          • 16
                          • south africa
                          do you maybe have sheme for me?
                          • wee wee
                            • Aug 2013
                            • 16
                            • south africa
                            for the two transistor flip-flop flasher can i use a irfz44, yg225c2,d718 or k512 ????? I only have those ???
                              • 30982
                              well i dont know.
                              you need a fet that can handle atleast 100w and have the lowest on-resistance you can find.
                              the lower the on-resistance, the less heat it will generate.
                              start by making a 555 circuit that flashes an led at the right speed, we can add the fet part afterwards.
                              it will be more easy to do this in 2 parts.
                                You should search for '555 application notes' to learn about 555.
                                I.E.
                                http://www.williamson-labs.com/555_apps.htm
                                It is best to learn how it works than just getting the schematic.
                                  • 30982
                                  looking at the timing charts i'd say you want a 10uf 50v capacitor and a 220k variable resistor to set the speed across a good range.
                                  • repair-it
                                    TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                    by repair-it
                                    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                    10-11-2023, 07:18 PM
                                  • fixit007
                                    Samsung flicker - BN44-00932T board or else?
                                    by fixit007
                                    I picked up this TV that the prior owner said - just died.
                                    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                    05-04-2024, 06:14 PM
                                  • sew333
                                    Can halogen bulb flicker?
                                    by sew333
                                    Hi. Yesterday i was in bathroom. And halogen bulb flicker for 1 second. Is this possible and why it flicker? Thx
                                    Bulb looking something like that:
                                    06-09-2022, 09:25 AM
                                  • ezenia
                                    LUMIMAN Smart Bulb IC ID?
                                    by ezenia
                                    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                    04-28-2025, 05:56 PM
                                  • sew333
                                    Light bulb flicker when turning on after long time off.
                                    by sew333
                                    Hello. I have question. I dont know if i have faulty wiring,bad installation or its bulb. When i have lights off long time and turn on lightning ( bulb halogen ) , there is a for 2-3 second bulb dimm/flicker and its normal. Happens only when lightning is off long time and i turn on.
                                    When i turn off lights and turn on again its fine. That flicker/dimm happens only when lights are off long time.
                                    That happens for example if i have lights off 2-3 hours and turn on.
                                    Thx
                                    02-16-2021, 01:39 PM
