Car flicker unit ...
    Hi guys,
    Just a little question for general knowledge ...
    In a car flicker unit for normal bulb, the blinking action is triggered by the bulb drawing amps.... if i got that right. So if you plug that same unit on a led light the led will just stay on because of the low amp usage.
    My question is, is it possible to fit this unit on a led by "cheating" with the amp consomation, I was thinking of if we put a resistor in parallel to the led? will it make it blink ?
    Thanx
    Cheerz
    Re: Car flicker unit ...
    not always.
    there are 3 types of flasher relay.
    the oldest type used a bi-metal strip with a heater on it, the current used by the bulbs heated the strip and cut the power, then it cooled and turned on again.
    and so-on.
    those are designed for a specific wattage and have problems with bad lamps or trailers.
    the newer type are electronic and the speed is fixed.
    a few of the very newest actually mess with the speed to indicate lamp failure - those are a pain.
    there is a thread here where a guy fucked one trying to fool it.
    show us the relay you have.
      Hi STJ,
      I have got those two relay;
      FR-109
      Flasher (mine is electronic brand but look the exact same)
      2P, 32CP, MA x 20
      12V
      and FR-113
      Flasher
      552
      2P, 32CPmax. 6
      12V
      Ref. http://www.allproducts.com/traffic/maiding/p11.html
      http://www.allproducts.com/traffic/maiding/p11-l.jpg
      What do you think?
        looks like it may be the old thermal type.
        put the led bulbs in and see if it works.
          Maybe a 4th type. Modern cars have a "bulb out" indication on the dash. The ECU looks for some expected current draw, and if the current is below what the bulb is rated for, your bulb out indicator comes on. A good place to get automotive led replacement units is superbrightleds.com. They will sell you a bleeder resistor that will keep your bulb out indicator from tripping when you install an led. But of course that defeats the purpose of using an led in the first place.
          Is it plugged in?
            if he has a thermal flasher, he'll need 20w resistors!!!!!
            for each bulb!!!!!!!!
              I tried with a 12v 10w bulb witch triggered the unit only once ... think the bulb is too week but don't have a bigger one.
              So if I get it right I must put a resistor of 40w since the unit is for two led at the time (+the one on the dash) in parallel with my LED?
                Why not just build a two transistor flip-flop flasher instead???
                  What is a 2 transistor flip flop flasher ?
                    hoo ok will have a look.
                    This one look simple:
                    http://homemadecircuitsandschematics...istor-led.html
                      so how many ohms should that resistor be?
                        forget the resistor, it's a dumb idea that wil be huge and generate stupid heat.
                        it would need to simulate atleast 42w or lamps, maybe 50w including side-repeaters.
                        just use the 555 chip to drive a transistor connected to a relay.
                        or even skip the relay and use the 555 to drive a fet on a small heatsink.
                          do you maybe have sheme for me?
                            for the two transistor flip-flop flasher can i use a irfz44, yg225c2,d718 or k512 ????? I only have those ???
                              well i dont know.
                              you need a fet that can handle atleast 100w and have the lowest on-resistance you can find.
                              the lower the on-resistance, the less heat it will generate.
                              start by making a 555 circuit that flashes an led at the right speed, we can add the fet part afterwards.
                              it will be more easy to do this in 2 parts.
                                You should search for '555 application notes' to learn about 555.
                                I.E.
                                http://www.williamson-labs.com/555_apps.htm
                                It is best to learn how it works than just getting the schematic.
                                  looking at the timing charts i'd say you want a 10uf 50v capacitor and a 220k variable resistor to set the speed across a good range.
