Two wattmeters: 0W and 25W, which one is true?
  • r-p
    • Feb 2013
    • 44
    • Netherlands
    See the picture. What is attached is a 0-30V 0-10A switch mode power supply from the early 90's (I think).
    One wattmeter claims it uses no power at all (which is what I expect, as it is switched OFF), the other claims >25W.
    I haven't measured inside, but the only explanation I can come up with is that the capacitor is before the powerswitch and that the cosine phi messes up the measurement.
    Not sure how, but that is the best I can come up with.
    Any ideas?
    I don't really understand PCF (power correction factor?), but does that have anything to do with it?
    The second pic is with the SMPS switched on without a load.
    The number under the powermeasurement on the Silvercrest is the powerfactor.
    Edit: in case it isn't obvious, the two powermeters are stacked, so the Silvercrest is measuring the SMPS and the second watt meter, the second watt meter is only measuring the SMPS. If the Silvercrest is only measuring the SMPS, it shows a similar result, which is why I tried this in the first place.
    Re: Two wattmeters: 0W and 25W, which one is true?
    The CAP across the AC line before switch will show current draw but will show close to 0 power (W) due to capacitive reactance.
    What readings do you get form both meters if you check the Wattage, Current, PF, VA using light bulb as the load?
    The meter that shows 28W, what does it show on VA and the current draw? AC line filter cap will not cause the meter to show 28W.
      • 31278
      the capacitor across the power inlet often has a discharge resistor in parallel actually.
      but no way will it pull 25w, it's usually only a .4w resistor.
      and i wouldnt put much trust into something you got from LiDL btw.
      i'm refering to the "silvercrest" kit.
      • r-p
        • Feb 2013
        • 44
        • Netherlands
        25W lightbulb, the front shows 24.6W (no V and A reading available), the Silvercrest 25.9W (about 0.118A and 229V equals 27W but might have read this a few seconds before the wattage measurement).
        Taking into account that the front meter adds to the draw measured by the Silvercrest, they are even closer (forgot to measure the draw of the lightbulb ONLY on the Silvercrest, but the wattage kept creeping down during the first minute, so that would add a measurement inaccuracy anyway).
        PF was 0.98 or so.
        The A measurement with the SMPS was 0.213A @229V with a PF of 0.60 and 29W (all values from the display). While only half plugging the 230V plug into the back of the SMPS while it is OFF, I can clearly hear arcing, so there is definately something going on before the powerswitch. New idea about this is that they have chosen this option because it has some remote control option.
        Here's the PDF for the powersupply, I am reading it now to see if that gives some moree clues.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I wonder. Maybe the one meter (not the silvercrest, the other meter!) uses a capacitor voltage dropping power supply. Might make it have horrible PFC, and the silvercrest shows it taking a lot of power (even though it actually isn't)
          Muh-soggy-knee
          • r-p
            • Feb 2013
            • 44
            • Netherlands
            This line was hidden somewhere in the back of my first, very long post
            • r-p
              • Feb 2013
              • 44
              • Netherlands
              Sorry for the slow answer, but I have since chalked this up to the Silvercrest being a piece of crap.
              • dkneyle
                Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                by dkneyle
                This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                02-01-2022, 02:08 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • abhishekkumar1902
                Huntkey HK340-72FP SMPS shut on load above 2 amps
                by abhishekkumar1902
                I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                I have checked the following:
                1. All output caps are OK, and all output rails read correct voltages at no load
                2. All output diodes are OK
                3. NTC is ok
                4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                5. No short in main switching MOSFET
                6. All other components...
                12-18-2022, 09:52 AM
              • madan1
                Mackie Th15 SMPS low Vout
                by madan1
                I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                It is basically a smps with amp and some dsp.
                The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                By the way, the ferrite core of L10 is broken,...
                02-16-2025, 04:15 PM
              • rewease
                Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                by rewease
                There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                09-17-2023, 12:53 AM
