What is this component please ?
+ More Options
Posts
  • diif
    • Feb 2014
    • 6978
    • England
    Hello, i repaired a Toshiba 22DL704B with a 17PW80 PSU.
    I had a shorted diode and I replaced all 5.
    Upon powering up there was a feint clicking but no picture.
    Upon inspection i found some solder blobbed around the part with 100 on the top. I flicked it off (it seemed like some had flicked a soldering iron with too much on), cleaned up the area and tried again.
    Success, but there is a slight whine upon turn on and the component is a little loose.
    Can someone identify the part with 100 on the top please ?
    Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: What is this component please ?
    That's an inductor, a coil of wire around a ferrite core, then put in that black plastic case.
    Whining is normal, when electricity goes through the wire inside the inductor there's a magnetic field produced which makes the wire expand or shrink a very tiny bit which makes it rub ever so slightly around that ferrite core, and that's what produces that wining sound (the very small expanding and shrinking happens about 10-30 thousand times a second).
    • diif
      • Feb 2014
      • 6978
      • England
      Thanks mariushm, that was quick. I guess the 100 is it's value ? It seems that it's the top that is loose but it has the insides attached, i have put a small blob of superglue to hold it on.
      Thanks again.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        100 should be 100uH. There are a few different codes for inductors, it's a bit more confusing than resistors. For example 1R0 would be 1uH, R56 would be 0.56uH, 22R would be 22uH and so on. Don't know why they use R, like for resistors, but that's what it is.
        That particular inductor had another piece of ferrite added on top to get to the proper value. It happens. And holding it down with super glue like you did will work just fine.
        A working TV? How boring!
          I heard R is used because L could be mistaken for an upside-down 7 or 1.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            What about H then?
            • diif
              • Feb 2014
              • 6978
              • England
              Thank you all very much, something new learnt today. Now if i can just get my friends LG tv fixed lol...my day would be complete.
              • dicky96
                Philips 37PFL5603/D Feint flickering picture
                by dicky96
                Hi guys, I got this Philips LCD TV here. I don't work on many LCDs, mostly LED so not had a lot of experience with them.
                I actually repaired this about 18 months ago - it had a bad AS15, which I replaced and it has been fine until recently
                Now it powers up, after several seconds the PSU makes a fizzing warbling noise (hard to describe) and I can see the CCFLs flkickering, then after some seconds it shuts down. It powers then back up again and the cycle repeats.
                The voltages to the main board are OK (3.3V, 12V, -12V). All the caps are visibly OK.
                07-22-2019, 06:19 AM
              • Svenskih
                My blade 15 2019 laptop is going through its middle age crisis
                by Svenskih
                Hi there, im wondering if anyone has any insight on my issue. i have a blade 15 2019 advance model. The other week something dropped onto my screen and cracked it (yikes!!!). i found a replacement online and installed it(not sure if this is the reason for my issue or just a coincident) i also do not have a battery installed. (it inflated some time ago and i opted not to have one)
                so out of the blue i tried to power on my laptop but it wouldn't come on. the power pack had its green light and i changed power sockets to check that. i wiggled the cable around and ensured it was all...
                11-30-2022, 06:26 PM
              • RetroComputingGrotto
                LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                by RetroComputingGrotto
                This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                On fitting the new LED strips I plugged in the TV was blinded by the light!!
                It was only when I partially put it all back together (including the screen) that...
                10-23-2024, 04:17 AM
              • Steelers
                Samsung UN46F5500AFXZA no backlight and no image
                by Steelers
                I am hoping someone can help me with troubleshooting this tv un46f5500afxza. The TV has no image. This tv was given to me so I don't even know if the screen is broken. Here is what I did so far:
                - I tried to use a flashlight but I don't see anything.
                - I took the tv in a dark room and took the back cover off. I see the backlight flickering but very feint. It flickers like once per second.
                - I disconnected the main board from the power board (BN44-00611A). Still same behavior as far as the backlight goes.
                - I plugged a laptop to HDMI port and I can get...
                01-02-2023, 07:07 PM
              • comptek
                Lg 55uk6950plb
                by comptek
                Hi everyone, I have an LG 55UK6950PLB, it started off with the LG logo then top top left hand corner HDMI2 comes up then fades away then just sound. Onboard t-con board not separate.
                I found a metal can capacitor at the top of the board in line with the LVDS sockets I measured 32 volts and it dropped off, I removed the ic below it and no picture so I assume it's needed lol, but the 32v still dropped off.
                I then removed IC9400 a 24 pin package and all the voltages stayed up and the screen works it's watchable besides some feint lines on the right hand side that seem...
                10-12-2022, 12:55 PM
