Samsung UN46F5500AFXZA no backlight and no image
  • Steelers
    • Sep 2022
    • Usa
    I am hoping someone can help me with troubleshooting this tv un46f5500afxza. The TV has no image. This tv was given to me so I don't even know if the screen is broken. Here is what I did so far:
    - I tried to use a flashlight but I don't see anything.
    - I took the tv in a dark room and took the back cover off. I see the backlight flickering but very feint. It flickers like once per second.
    - I disconnected the main board from the power board (BN44-00611A). Still same behavior as far as the backlight goes.
    - I plugged a laptop to HDMI port and I can get sound.
    I would buy a new power board or kit but I don't even know if the backlights/LEDs are working. I appreciate any help I could get.
    Thank you all in advance
  • nomoresonys
    • 12206
    • U.S.
    Re: Samsung UN46F5500AFXZA no backlight and no image
    probably a backlight issue, think I would just take it down to the backlights and see what's going on, the panels are very easy to break so need to treat them very gently, 46 isn't as hard to deal with as the bigger ones tho.
    • nomoresonys
      • 12206
      • U.S.
      could do the usual easier tests on the powerboard, check all solder joints, test the diodes and resistors etc.
      • DarkGT
        • Dec 2022
        • 9
        Similar flashing frequency with my Samsung TV, it turn out to be burned LED's, few still complete the circuit that's why it's flashing from time to time. There are guides as pinned topics in the forum to start measuring and checking stuff.
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • wolf1976
          samsung ue40d6100 has no backlight no sound and image
          by wolf1976
          hi to all
          on the above model of samsung i have the faults i have told already on the title
          iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
          any idea from someone what can i measure so i can find the problem ?
          the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
          11-17-2024, 01:02 PM
        • mi16rs
          SAMSUNG UE32M4005AW BACKLIGHT OK BUT NO IMAGE
          by mi16rs
          Hi i have a samsung UE32M4005AW that have backlight but no image , i have changed the main board but still the same problem , so i guess it as a fault on the panel board , could some one help me on this ? thanks...
          02-08-2024, 03:19 AM
          09-07-2024, 05:50 AM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
