I work for a school bus garage and we use lighted extension cords for our engine block heaters in the winter. We use these so we can quickly check each bus for a working block heater before leaving for the night. Our problem is we cannot find reasonably priced lighted cords, cannot find cords with lights that work for a long time, some (usually new) get torn up when a driver forgets to unplug. We also cannot find replacement lighted ends. Is there a way to make inductive pickup lights, neon or LED to put on our cords? We are trying to control costs wherever we can, our taxpayers are being stretched thin around here in Indy. Thanks!
110v inductive pickup type of light
From my favoritest movie ever!:
Cledus Snow: Can I ask you a question?
Bo Darville: Sure, ask me what?
Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.Tags: None -
Re: 110v inductive pickup type of light
If I were to try to solve this I think I would look for some clear male ends and solder a small neon with a resistor across hot and neutral. It would need replaced periodically as they dont last forever. If you couldnt find clear I suppose you could also drill a 5mm hole in the side of a opaque plug and fit an led (would also need a current limiting resistor).
If you want to go really simple a 3 way with a night light plugged in at the block heater would workLiberating magic smoke one part at a time -
Thanks, Caleb. Could you elaborate on the 3 way idea? Thanks!Last edited by Poor Flick; 10-04-2014, 10:17 AM.From my favoritest movie ever!:
Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.Comment
just a standard 3 way plug with a mini night light into one plug, and the core heater into the other
pictures not mine but this should give you the basic ideaAttached Filesif you find these attachements useful please consider making a small donation to the site
Liberating magic smoke one part at a timeComment
I might be able to make that work, if the light is at the male end at the plug in stand. (no room in the block heater socket) that would still show us if a GFCI has tripped. Maybe a plexiglass window in the plug in stand. Thanks, Caleb!From my favoritest movie ever!:
Yours dont have a cord hanging out? My diesel has about a foot of cord. If you really want it at the bus you could make up a shorty cord with 1 male and two female ends using standard plug end and extension cording.Liberating magic smoke one part at a timeComment
Caleb, most of our busses have weather resistant plug covers in the front bumper area. I found a similar picture on the internet. If we made 1' short cords we could put the lights at the bus. Easier and more visible than putting windows in the plug in stands. I am thinking your night light idea is the answer, may require some silicone sealant for weatherproofing. Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
Not that I don't approve of doing it the hard way, but how about this:
http://products.ericson.com/item/ect...ctors/5269-el?
7$ doesn't sound like much and would probably make it harder for drivers to forget about unplugging seeing it all lit up.Comment
Thanks, tool49. This is what we were looking for at first, we've tried the local hardware stores and "home centers" here in Hooterville/Indianapolis, they didn't have them. Our building maintenance guy had some electrical supply sources and they were available for just as much as a new cord. When I go back to work Ill see if we can get some ordered. I myself am for the easy way usually, it's time consuming enough to keep 83 diesels running in the winter and we have state police inspection in the early spring. Many thanks to you and Caleb!From my favoritest movie ever!:
by t4796Hi all,
I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
From the FAQ I learnt that for 110v the power...1 Photo -
by sam_sam_samI just seen this item is this a good idea if why and if not why not
Here is the website link to it
https://www.ebay.com/itm/40599879518....c101465.m3507 -
by maleksaI need help to ascertain if the power supply on my Yamaha SY85 keyboard is 110v or 220v or both.
I have attached the schematics below.... -
by anupkg1985Hi,
I have got a xbox 360 console from India where it has an adapter designed to work with 200v-240v (135 watts) and has o/p voltages of 5v 1A standby and 12v 10A as operating voltage. Is there any way to modify the same to work on 110v in USA? -
Hello
Anyone came across datasheets for the laser pickups:
EP-HD870PB
SF-HD870
I want to know the differences if any-
- Loading...
