? about votlage.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    ? about votlage.
    On a CCFL LCD TV what would consider too low of a voltage?
    I have a sanyo TV with what appears to be a T-CON issue. Left side of screen is black, but eventually will come on after 10-15 minutes.
    Taking voltage measurement on the 12v and 5v rail, I get 11.73v and 4.84.
    I'm wondering if low voltage is an issue? Still waiting for set to warm up a bit and for the left side to start displaying a image before I take the next measurements. I expect no change.
    • 31283
    Re: ? about votlage.
    set your meter to "AC" and read the voltages again - that usually tells you the ripple.
    ripple is an indication of the state of the capacitors.
    • cheapie
      null
      • Jul 2010
      • 849
      Don't most meters just rectify the power coming in, then do some funky math to get the AC voltage? Besides, at the frequency these power supplies run, I doubt that the meter would be able to read it even if it did just read the AC component.
      For example, on my Seasonic "Platinum-660" (SS-660XP²), using some random cheap meter, the 12V rail reads 12.06V with the meter set to DC volts, and 26.0V with the meter set to AC. The 5V rail reads 5.05V with the meter set to DC, and 10.4V with the meter set to AC. I didn't measure the 3.3V, -12V, or 5VSB rails, but I'd imagine they're similar. I also inadvertently found that the short-circuit protection works when I forgot to change the meter from amps to volts... that made quite a spark.
        • 31283
        some meters make a mess of the readings, but a lot give the ripple.
        they do rectify the voltage, but they dont smooth it.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          If you have a way to operate the set with the tcon exposed, try gently heating it w/ hair dryer or (carefully!) heat gun.
          Did this get worse with time or happen suddenly?
          Are you measuring 5 & 12 on the tcon, main board, or power supply?
          How does the left side look as it comes back in- does it slowly "wipe" towards the left side and bounce around, or snap back, all at once?
          When you say left, do you mean left-of-center, or the leftmost 5-6 inches?
          Capxons, Hermeis, or Teapos by any chance?
          Sorry for all the questions, just trying to get a feel for this set.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
            by momaka
            03-15-2023, 10:17 PM
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • lefetylorant
            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
            by lefetylorant
            Hello Everyone,
            Long story short, I got this unit for very cheap.
            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
            I've performed some measurements:
            - 20V rail perfectly...
            09-14-2023, 05:05 AM
