Can someone help me find this component so I can get my fan working on this HD 7950
  • Rob
    • Oct 2005
    • 47
    Re: Can someone help me find this component so I can get my fan working on this HD 79
    I soldered the 2N3904 Surface mount transistor on and all the fan does is twitch. It never did twitch so it tells me that maybe the transistor is not allowing enough current perhaps? I did solder it twice with 2 different transistors to make sure I didn't mess up. Both same outcome.
      • 31139
      meter the fan wires to check the voltage.
      and it may sound obvious, but did you actually test the fan?
      • SteveNielsen
        Retired Tech
        • 2327
        See post #3
          Check the Base-Emitter voltage to see if the base drive is pulsing also.
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • Rayblaster
            HP RP7 RP7800 from 2012/2013 worst fault - has "character"
            by Rayblaster
            Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
            I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
            12-30-2024, 06:28 PM
          • modtool
            HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
            by modtool
            Dear colleagues,
            I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
            The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
            Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
            05-07-2025, 06:10 AM
          • hopkok
            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
            by hopkok
            Hi masters, I need your help.
            I am working on Lenovo Legion 16ITHg6
            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
            Power LED is not working as well, power button working well.
            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
            Motherboard...
            05-04-2025, 09:35 AM
