Can someone help me find this component so I can get my fan working on this HD 7950
  • Rob
    • Oct 2005
    • 47
    Bottom image is what belongs on the board.
    Its labeled AFBV 1A. I can't find any data anywhere on this.
    Thanks all!
  • chozo4
    Nothing Special
    • 134
    Re: Can someone help me find this component so I can get my fan working on this HD 79
    What is not causing the fan to work to begin with? Is it a bad component, bad fan, or just a different hookup? Cannot find the AFVB 1a on the pictures due to being blurry. The alternative would just as well be to wire the fan to a separate power source from the PSU if it's just not getting power at all. If it's working but not being controlled via voltage or PWM then that's a different story.
    edit: OH! I see now after closer inspection as it was very hard to see the thin dark blue circle in there.. that's actually a surface mount transistor to help get you started. Seems to be more related to the PWM circuitry I would assume. I'm blindly assuming it's a NPN tranistor and from a quick look this looks something close to what you need. It hands up to 0.6A but most fans, even for a GPU won't even go that far if it's being used to handle fan duty.
    umt2222a/SST2222A
    Just for future reference... components marked with a Q (Q12 for example) at the start indicate tranistors. However, before you start adding components though, what is actually wrong with the fan functionally?
    Even crap caps can be useful... such as blank rounds for prop gunfights.
    • Rob
      • Oct 2005
      • 47
      Fan works fine, the card will not run the fan off the header. I want to replace that transistor so I can run it through the actual card.
      Thanks for the advice, I was super lost for a while.
      • chozo4
        Nothing Special
        • 134
        hmm, if at worst you could make sure there are no traces running from the + of the header to anything (as in not connected to anything). Then after you can just use a multimeter to find where the voltage for 12v,5v, whatnot is coming in and run a jumper wire from there on the card to the header. Then after you can use the header accordingly. Just double check where each of the 2 traces go to be sure.
        • Rob
          • Oct 2005
          • 47
          I ordered an SST2222A transistor and will solder it on once it arrives. Unless I completely hack the solder job I hope this does the trick.
            Before removing that transistor, you should check the voltage on the Emitter and the Base using both DC mode and AC mode on the meter to see if it is getting the drive signal or not.
            • chozo4
              Nothing Special
              • 134
              Their issue is that it's missing the transistor and only an empty pad rather than removing an existing one. I assume it's probably originally made for a passive sink than to run a fan otherwise hence the lack of a header and transistor to drive it.
                • 31137
                then it's probably also missing the base drive resistor and maybe other stuff too.
                • Rob
                  • Oct 2005
                  • 47
                  The rest of the components are in tact. This was knocked off by someone who was a little rough at uninstallation. I located almost every single component on the board, everything else is definitely still there.
                    master hoarder
                    • May 2008
                    • 12175
                    Could be a 2N3904, then - a standard NPN transistor good for 200 mA and 350 mW. It's SOT-32 version is MMBT3904, but it's marked as "1A".
                    The 2222 you got would likely work fine too, though. In the SOT-23 world, it is known as "1P" and possibly other part numbers as well.
                    • chozo4
                      Nothing Special
                      • 134
                      Good to know then momaka. I have little to no experience with a majority of surface-mount parts so was generally a shot in the dark with a general idea. Good to know I was at least spot on for the most part.
                      • Rob
                        • Oct 2005
                        • 47
                        I also ordered MMBT3904 since it was in the states. These will come in faster. They are cheap enough where I won't be upset that I have 100 pcs of a transistor I will never use.
                        • jetadm123
                          • 2169
                          I know it's a little late, but Radio Shack does sell the 2N3904 and 2N2222 transistors. They are not surface mount, but regular transistors with leads. However, you can bend the leads to fit the pads on the board. Saves a lot of waiting time and you don't have to buy a 100.
                          • Rob
                            • Oct 2005
                            • 47
                            I wish I knew that sooner. It's ok though because I had to order new thermal pads for the ram and VRMs anyways. The old ones were degraded.
                            • Rob
                              • Oct 2005
                              • 47
                              Would I have been able to leave the leads longer and then hot glue it flat to the PCB? It would probably be easier to solder. How do I know which lead goes where on the PCB?
                              • jetadm123
                                • 2169
                                Download the datasheet for the surface mount version, then compare the leads to the ones on the package of the new transistor. Always pre-bend/cut the leads prior to soldering.
                                  Example of how I do it:
                                  http://s807.photobucket.com/user/bud...ml?sort=3&o=27
                                  http://s807.photobucket.com/user/bud...ml?sort=3&o=26
                                  • Rob
                                    • Oct 2005
                                    • 47
                                    Found one:
                                    Looks like the collector isn't in the center on the regular transistors like they are on the surface mount. I will have to either have it stand straight up or lay it sideways to make it work. I may just wait for the surface mount transistors to arrive but it still maybe easier to solder the regular one on due to the longer leads.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      That's why we highly suggest to put at least the state and country in your profile.
                                      I have plenty of dead hardware that has these transistors and could have pulled a few and mailed them to you in a regular mail envelope.
                                      Surface mount is easier to solder if you have the right part.
                                      Leaded components can work on SMD, but you have to be careful and pre-bend the leads before soldering anything, as jetadm123 noted. Otherwise, you could damage the SMD pads if you accidentally bump the transistor or try to move it around with the leads soldered.
                                      • chozo4
                                        Nothing Special
                                        • 134
                                        I think it's fair to say we all have something chock full of transistors to spare. Salvaged broken up boards from a destroyed projection TV with more transistors than I will possible ever need for a lifetime.
                                        • aaronkatrini
                                          Help me find the short circuit on this WORKING Nvidia GTX1650
                                          by aaronkatrini
                                          Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                                          Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                                          04-18-2024, 03:15 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • Rayblaster
                                          HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                          by Rayblaster
                                          Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                          I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                          12-30-2024, 06:28 PM
                                        • modtool
                                          HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                          by modtool
                                          Dear colleagues,
                                          I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                          The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                          Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                          05-07-2025, 06:10 AM
                                        • hopkok
                                          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                          by hopkok
                                          Hi masters, I need your help.
                                          I am working on Lenovo Legion 16ITHg6
                                          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                          Power LED is not working as well, power button working well.
                                          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                          Motherboard...
                                          05-04-2025, 09:35 AM
