search datasheet for 0N4986 transistor
    AO4601 AO4601L Transistor (Applications Laptops) Datasheet
    Complementary Enhancement Mode Field Effect Transistor
    The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
    11-05-2024, 08:21 AM
  • Pavithra Munasinghe
    E1A38 transistor datasheet
    by Pavithra Munasinghe
    Highly appreciate if you could provide the datasheet of E1A38 transistor.
    09-03-2024, 10:54 PM
  • Raygen
    No VCC to bios chip - Huawei Matebook d15 DAH98AMBAD0 REV:D HF Model H98A H898A
    by Raygen
    Hello, I received to repair this Huawei laptop (model in the title).
    The laptop will charge the battery fine throught the USB C port, but it wont turn on. The charging led will blink fast and repeatedly when trying to turn it on.
    I've attached photos of the board. (the wires are for briging the power button, I did not inject voltage)
    Upon visual inspection, a couple of ICs were blown. Along the 5V line leading to one of the USB A ports. They wasnt fully shorted but just a couple of ohms to ground.
    I replaced the blown IC on the board (the one circled in red,...
    09-23-2024, 04:21 PM
  • magneh
    Behringer Eurolive B205D repair - help identifying transistor
    by magneh
    Hello
    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
    Still, I need to replace this transistor....
    06-18-2025, 02:34 AM
  • SoulFreeze
    Help finding datasheet for component marked G34662
    by SoulFreeze
    Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
    Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
    Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
    05-01-2025, 03:56 AM
