AO4601 AO4601L Transistor (Applications Laptops) Datasheet
    Complementary Enhancement Mode Field Effect Transistor
    The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L
  • Pavithra Munasinghe
    E1A38 transistor datasheet
    by Pavithra Munasinghe
    Highly appreciate if you could provide the datasheet of E1A38 transistor.
    09-03-2024, 10:54 PM
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
  • NanoTesting
    Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
    by NanoTesting
    This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
    Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
    02-21-2025, 12:33 AM
    BrightKing KD07 Metal Oxide Varistors (MOV) Datasheet
    Metal Oxide Varistors (MOV) Data Sheet
    Features
    ● Wide operating voltage (V1mA) range from 18V to 820V
    ● Fast responding to transient over-voltage
    ● Large absorbing transient energy capability
    ● Low clamping ratio and no follow-on current
    ● Meets MSL level 1, per J-STD-020
    ● Safety certification: UL: E327997 CSA: 246579 VDE: 40027827
    Applications
    ● Transistor, diode, IC, thyristor or triac semiconductor protection
    ● Surge protection in consumer electronics
    ● Surge protection in industrial...
    10-07-2024, 05:58 AM
    FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
    BOOST CONVERT CONTROL IC
    The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
    FP5139 FEATURES...
    10-07-2024, 05:15 AM
