Help Identify 1 componente From a Thrustmaster wheel
This topic has been answered.
  • OnRepair1
    • Oct 2022
    • 33
    • Portugal
    Hi i have been looking at a wheel from thrustmaster T300 there is a componente that its burn out and its impossible to read the code on in
    The componente is the Q17 (Next to the fuse FB34) it seems that its starts with a 2 but nothing else i can see.
    Does someone know or have the schematics of it?
  • Answer selected by OnRepair1 at 04-23-2025, 08:08 AM.
    lotas
    • Jan 2016
    • 4653
    • Russia
    FB34 is not a fuse, but a smd choke. 2A - PNP transistor MMBT3906, put any from the table.
    • harp
      • Jun 2022
      • 606
      • Planet Earth
      Make note of all other sot23 marking on board, it is not likely that is only one start with 2... common is 2A (npn), 2T (pnp)... the sharp picture of that area will also may help, and connection diagram.
      • truclacicr
        • Apr 2019
        • 322
        • australia
        It looks like "2Ax".
        https://www.reddit.com/media?url=htt...384eedde2911ec
        • OnRepair1
          • Oct 2022
          • 33
          • Portugal
          Here is a closup picture Click image for larger version
          • lotas
            • Jan 2016
            • 4653
            • Russia
            • OnRepair1
              • Oct 2022
              • 33
              • Portugal
              Thanks, i will try to replace it i have order it and will let you know if its all working now
              • baiceanu_stefan
                nm-f251 Schematic, boardview or help identify componente
                by baiceanu_stefan
                Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                04-24-2024, 12:49 AM
              • AJ847.63e
                BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                by AJ847.63e
                Hi All.
                Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                09-18-2023, 06:42 PM
              • thesame
                DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                by thesame
                Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                02-27-2024, 04:31 AM
              • silver60618
                Lenovo Legion 7 - Help Identify IC
                by silver60618
                Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                Any help would be appreciated...
                07-02-2025, 12:16 PM
              • chth96
                How can I identify varistor which have been blew up?
                by chth96
                I mistakely pluged 100v japanese retro game console to 220v outlet.
                So It seems that glass fuse and varistor have been blew up.
                I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                Is there any way to identify varistor type in my sega saturn PSU?
                Any reply would be appreciated.
                EDIT:
                It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                11-26-2023, 08:52 AM
