Of a pcb with markings ST180 could anyone help with replacement part
Relay identification please :)
Tags: None
terrible design is a complete understatement, worst I have seenComment
Transformers are supposed to look like shorts, it's just a long piece of wire inside after all.
Transformers tend to be custom for the design. Is this a switch mode power supply? Can't tell if it's an EI or ferrite core, looks like the latter and hence a switch mode, but the circuit around it looks wrong.
Will need more data, better pictures of board surrounding it...Comment
This is why the question was asked what type of device is this board used in please post some pictures of this device plus all of its board front and back of each boardLast edited by sam_sam_sam; 04-12-2025, 11:22 PM.Comment
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by petehall347smd package .measures roughly 4x2 mm so thinking its DO-214AC markings are SA then under it is 39 .i believe 39 to be the date code .
will see if suggestions are same as what i think it might be . -
by MufasaHello everyone,
I have a bad mosfet and need to replace it but I don't know who makes it. I think it's Infineon. The markings say "L8=8H 33R". Does anyone know what it is for sure and where to find it?
Thanks in advance!! -
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... - Loading...
