zener tester
+ More Options
Posts
    • 31183
    zener tester
    this is old, but very simple.
    and it works.
    i decided to share.
  • SteveNielsen
    Retired Tech
    • 2327
    Re: zener tester
    Cool. Could you use a multimeter set on 200mV range instead of the Maplin gw01b?
    • selldoor
      Slow Learner
      • 7870
      Re: zener tester
      Should probably be stickied in somewhere in the TV section or in the equipment section
      if you want to ask a mod to move it
      • SteveNielsen
        Retired Tech
        • 2327
        Re: zener tester
        Equipment forum is probably most appropriate but it seem ok here to me too.
          • 31183
          Re: zener tester
          not unless you want to blow it up.
          you set your meter to 200v or higher.
          i built one without the meter and connect it to my multimeter.
          the circuit generates a ramping voltage that starts at 0 and rises to over 200v
            • 31183
            Re: zener tester
            just to add, if you use your multimeter, you connect it across the zener
            • SteveNielsen
              Retired Tech
              • 2327
              Re: zener tester
              Sorry, I misread some stuff. Thanks for the info.
                Re: zener tester
                If you already have variable output DC power supply, than all you need is the resistor to limit the current through D.U.T. and the meter hooked up across the D.U.T.
                Or build this portable tester.
                  • 31183
                  Re: zener tester
                  shall i draw a modern schematic of a variant that uses a multimeter and a more common transformer?
                  • SeanB
                    • Jun 2013
                    • 41
                    • South Africa
                    Re: zener tester
                    I built one years ago using a small surplus 60VAC transformer and a 10mA constant current source. Was quite useful to test zener diodes or to use as a simple 10mA current source. I built it to handle a 80V zener that we used that would fail every so often, but it was also useful to test high voltage rectifier diodes that had a 20V or so forward voltage drop. Reverse voltage testing on those was with a 10kV insulation tester, which would show any gross faults, but which was not much use as the equipment in question ran at 30kV on the anode. At least the 10kV allowed us to trouble shoot without burning up anything else in the test phase. It was way to high for any other use, as it would happily kill any mains rated cabling it was attached to, and would make things like sockets arc over internally.
                    • Mr.Orange
                      • Aug 2014
                      • 12
                      • Ireland
                      Re: zener tester
                      Built a simple one years ago for testing zeners from a blacklisted supplier, the only supplier (Arrow) that had that value. One of the production staff had to sit there all day testing zeners , felt sorry for them but they said is was relaxing. about a quarter were within tolerance. Anyway power supply a suitable watt resister (could just use a couple in parallel) and a bench meter does the job.
                      A simple cheap SMD airflow tool is a handheld gas soldering iron without the iron :. is a selective hot airflow which can be regulated by turning up/down gas, also no onerous air lead. I have replaced many components without damaging them or the solder pads all within seconds... can also be used as a soldering iron & on heat shrink
                      • caspian
                        What Zener Diodes on a Linear Power Supply
                        by caspian
                        Dear members,
                        I have a linear variable power supply with unknown brand name that I used for voltage injection.
                        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                        In addition, I discovered that its zener diodes are defective.
                        I can replace the burned transistors.
                        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                        Therefore, I cannot replace the zener diodes.
                        I do not want to test the zener diodes in a test circuit to discover their model or value.
                        no schematics are available...
                        05-26-2025, 12:38 PM
                      • Dvsr
                        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                        by Dvsr
                        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                        After replacing the caps I started testing out the speaker. It seemed...
                        09-10-2025, 10:20 AM
                      • nev1001
                        What zener diode might fix the sound on Maestro Mayhem gaming chair?
                        by nev1001
                        Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                        The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                        It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                        I think an issue could be a zener diode (or capacitor) which has shorted out.
                        The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                        04-17-2025, 05:09 PM
                      • piernov
                        Reminder: rules and organization of this section
                        by piernov
                        Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
                        I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
                        Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
                        This section and its subsections are about the following classes of devices:
                        • Desktop computers
                        • All-in-one
                        03-31-2023, 06:17 AM
                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                        by sam_sam_sam
                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                        I bought this from an eBay seller but unfortunately they only had one
                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                        I bought three of from them to also make battery packs with this output power limit in mind
                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                        04-23-2025, 05:50 AM
