Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
    • Jul 2011
    • 6070
    Originally posted by stj
    never recycle ipads,
    you can buy a small pcb that lets you re-use the display as a monitor!
    Yes I have seen them on EBay but my question is how easy is it really to do my biggest issue is to get the IPad apart which I have never done before I have seen several how to do YouTube videos but from what I can see is they do not really tell when you are heating the screen when it is ready to take apart with out damaging the screen or the digitizer which is required for use as monitor but would help protect the screen
      • 31290
      you need to heat it evenly so something like a hot water bottle is handy,
      and try to pull the screen out with suction cups - never pry it with a tool.
      cant really add much - these taped in designs are a pain.
      if you where gonna scrap it you have nothing to lose though.
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
