TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
The specs says ...
High antenna efficiency 868MHz ISM Band
5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
1. Should I Fix it with a glue.
2. Should I fix it with a double side adhesive tape
3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium plate - there is about 1mm on three sides and 0 mm on one side between the ceramic and the perforated metal plate.
I am confused can someone help me out.
Antenna url
https://www.mouser.in/datasheet/2/39...2E-3137376.pdf
The specs says ...
Antenna url
