Machine - reset pass code
+ More Options
Posts
  • Dessied
    • Apr 2014
    • 10
    • Ireland
    Hi All
    First post here, hope to get a steer on an electronic problem. A friend of mine runs a beauty salon on her own and purchased a machine a few years ago - square box around 30" x 12" x 5". Paid a lot of money for it which she didnt really have.
    About 2 months ago it suddenly prompted for a pass code. The firm has gone bust and there is no way of her getting a code or support. I'm from a software background, but said I'd take a look, only thing I could think of trying was seeing if there was a cmos battery, and removing it to see if it would reset.
    Opened the box and was amazed to find only one very simple circuit board! I can see a battery but it appears to be secured by a weld. Before I force it out, I'd appreciate if anyone thinks it's worth a shot. Can post photos if it helps.
    Sorry if this is the wrong forum, and really appreciate any feedback.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Machine - reset pass code
    pictures and any make and model details will help.
    • Dessied
      • Apr 2014
      • 10
      • Ireland
      Sorry, you're correct lack of info in my first post .
      For make & model there's not much to go on - the machine is called "Microlift" and bar a serial number there's nothing else I can find. Tried Google etc of course but nothing.
      Attached a few photos:-
      1 - The message that displays which is "System Code 18 - Press any ket to continue". When you do it looks for a code.
      2 - The Microlift box
      3 & 4 - Two pics of the only circuit board. You can see the battery which is standing upright. I've no idea on the rest, but doesn't look to be much there.
      If I can send on anything else that may help please let me know. And thanks for the VERY quick response vinceroger69...
        Does she has any user manual? What does it do or what is it used for? It looks like facial treatment machine from around 2003.
        • Dessied
          • Apr 2014
          • 10
          • Ireland
          I'll check re: manual but don't think so. It is a facial / body toner (whatever that means) and yes, looks like 2003 alright! Probably why I can't find anything to do with it on Google etc.
          She was using this fine up to a few months ago, but one day, switched it on and it started looking for.a code. Only thing I can think to try is to take out the battery and see? There's no jumpers etc. would be nice to help her out cos she spent a lot on it and hasn't had much in the way of luck recently...
            The design looks pretty old, I would guess late 90s. I'm not sure what it does, given there looks to be very little inside of it... There looks to be a socketed device which might be an EEPROM for settings and two microcontrollers, one for the display and one for everything else, I am guessing.
            Looks like it has two wires for electrodes, some kind of electro-therapy nonsense as we've seen before here?
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              http://www.triangelklinikken.no/Microlift_salg.html
              what does that text printed on the PCB in pic 4 say?
              Follow the white rabbit.
                • 30953
                the battery is probably flat for a start.
                it looks like a glorified TENS unit btw.
                • bluto
                  • Oct 2007
                  • 560
                  12345?
                    BTW, did you check the voltage on the battery? It is more than 10 years old so I will not be surprised if it is dead.
                    • Dessied
                      • Apr 2014
                      • 10
                      • Ireland
                      My God, how did you find that, it's the exact same machine!
                      I've uploaded a zoom of the PCB text. Thanks for the feedback.
                        goontron, you're good!
                        • Dessied
                          • Apr 2014
                          • 10
                          • Ireland
                          Probably, the image above showing the PCB text includes the battery close up - it appears to be welded to the two vertical metal flaps so will require a bit of force.
                          Originally posted by bluto
                          12345?
                          Tried this, alas no joy, thanks anyway would have been a quick fix
                          Sorry, not sure how to, more of a software slant than hardware. IBut I guess you're right, chances are it's dead, unfortunately it's welded rather than a simple clip.
                          Yeah you're right in it is some electro-therapy thing. Check out the link from goontron - that's the exact same machine.
                          Thanks everyone, much appreciated. Guess my last question now is should I yank the battery and try a new one as doesn't appear any other option?
                          • Dessied
                            • Apr 2014
                            • 10
                            • Ireland
                            I'll echo that!
                            Looking at the website, the before and after pics don;t show much of a difference....
                            I'm putting the lot through bablefish now to see if I can find anything
                              Since they are still in business and they even have E-mail address:
                              Tlf: 22 25 09 00
                              btria@broadpark.no
                              I would check the batteries for sure.
                              • Dessied
                                • Apr 2014
                                • 10
                                • Ireland
                                Tlf: 22 25 09 00
                                btria@broadpark.no
                                Agreed budm, just dropped them a very broken english mail looking for a code, if I don;t hear back I'll try the battery option. Sure I'll let ye know how I get on out of interest
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  well, from what i can find they are gone. i found a link to here
                                  http://www.ioxfordshire.co.uk/profil...rnational-Ltd/
                                  then when its put into google maps its shows up as Arrow Autocare, a garage.
                                  i cant fix a TV for anything but tell me to look for something on the web and i will find what others cant!
                                  maybe this is them?
                                  http://bdmitech.com/location.aspx
                                    • 30953
                                    NO!
                                    that's a pcb mounted battery - the tabs are part of it.
                                    you replace the whole thing with another - or a socket.
                                    you need to get the part number etc from the battery so we know if it's a disposable lithium, or a lithium-thionyl rechargable.
                                    • Dessied
                                      • Apr 2014
                                      • 10
                                      • Ireland
                                      Goontron, thanks again, you should be a private detective.
                                      Stj - phew had the pliers in place when I read your post. I'll dismantle it tomorrow an see can I get the part # or a replacement.
                                      This is becoming a bit of a mission now!
                                        LCD LED TV Service Menu Codes
                                        ALL LCD LED TV SERVICE MENU CODES
                                        Service Menu Code with Board Name
                                        China Universal Board / Jumper Board Service Menu Code
                                        Changhong Ruba Service Menu Code
                                        Ecostar LED TV Service Menu Code
                                        Orient LED TV Service Menu Code
                                        Haier LED TV Service Menu Code
                                        TCL LED TV Service Menu Code
                                        Samsung LED TV Service Menu Code
                                        LG LED TV Service Menu Code
                                        Videocon LED TV Service Menu Code
                                        Supra LED TV Service Menu Code
                                        Toshiba LED TV Service Menu Code
                                        Symphony LED TV Service Menu Code
                                        Veste/ LED TV Service Menu Code...
                                        10-31-2024, 03:58 AM
                                      • CG2
                                        Janome DC3050 Sewing Machine Pedal Resistance
                                        by CG2
                                        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                        04-14-2023, 07:53 AM
                                      • Soulzink
                                        Samsug washing machine. Power supply DC41-00189a board issue
                                        by Soulzink
                                        I am trying to fix a samsung washinmachine power supply main board.
                                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                        The power supply board reference is the following: DC41-00189a
                                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                        04-19-2025, 06:26 AM
                                      • Fam787
                                        HELP! A1398 Dead,
                                        by Fam787
                                        I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
                                        Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
                                        12-27-2024, 05:19 PM
                                      • microwave_highvoltage
                                        Old BIOS request(s) T550 and/or T440
                                        by microwave_highvoltage
                                        Hi there!
                                        The following request might well shatter the rules, however I ask you to read through to understand.
                                        I am looking for BIOS updates and or dumps from BIOSes that haven't been updated since December 2016 or have been saved before January, 2017,
                                        targeting ThinkPad T550 and/or T440. These are supposed to be TXT and/or Boot Guard enabled which is exactly what I'm looking for.
                                        Since I do not (yet) own a ThinkPad I cannot share a BIOS dump nor do I know a serial number.
                                        Why do I need this?
                                        I am very interested to see a special kind of...
                                        05-29-2025, 07:49 AM
