Infinity TSS-450 sub assistance
  • jibber
    • Mar 2014
    • 8
    I have this TSS-450 sub that has been great for 7 years, It recently started making noise after about 3 min of running (works flawless at first). It starts with a hum and then all hell breaks loose when the squelching vibration starts in.
    I pulled it apart to find some pretty warm areas under a few 3 leg transistors? And a couple of the small caps.
    Any direction on where to go now would be great!
    Josh
  • jibber
    • Mar 2014
    • 8
    Re: Infinity TSS-450 sub assistance
    Is there a method of testing these transistors? I am assuming the mosfets are attached to the heatsink.
      Post good well focused pictures will be a good start.
      • jibber
        • Mar 2014
        • 8
        Will do the next time I am at home. I have the board pulled out already. Thanks!
        • jibber
          • Mar 2014
          • 8
          Here you go, you can see the discoloration on the board where it got hot.
          Thanks for any help you can provide.
          Josh
            master hoarder
            • May 2008
            • 12164
            If it works fine but then starts having problems, you are looking at either bad solder joints, thermal runaway on a semiconductor, or perhaps those electrolytic caps in the hot areas are going bad.
            My #1 advice would be to replace all caps in those areas where it gets hot as they have likely gone dry by now. Better yet, replace all caps, except possibly for the big two. Use good quality 105C rated Japanese parts (so Panasonic, Nichicon, Rubycon, or United Chemicon). Order from Digikey, Mouser, or badcaps.net/store (this place). Avoid local stores/Radio Shack for caps - they don't sell suitable caps. And more than anything, AVOID eBay for caps and replacement transistors/ICs (too many counterfeits).
            Next, check all solder joints, and if in doubt, resolder any that look dry. You may also want to resolder the joints on that transistor that seems to have been running hot (Q117?), even if they do look good.
            You also have some tan glue on the right side of the first two pictures you posted - now that stuff tends to go conductive, especially over time with exposure to moisture and heat. Clean it off - at least from the leads on components.
            If you have some piece of scrap aluminum, consider making a heatsink for that hot transistor. Maybe the others behind it too if they are running hot and discoloring the board.
            That's as far as my suggestions go for now. I'm no expert in the matter of amplifier problems, but in general when things are running hot or have ran hot, I always change the caps in those affected areas because they often go high-ESR.
            • jibber
              • Mar 2014
              • 8
              Thanks for the time looking at this. I will pull and log all the caps specs and their board locations. I have been successful purchasing from digikey before so I will try them first.
              After I get all the caps replaced and the tan glue cleaned off I will let you know how it all worked out.
              Thanks again for the space and the assistance!
              Josh
              • jibber
                • Mar 2014
                • 8
                So I replaced 11 of the 12 small caps.... I missed one when ordering. I also re soldered a number of the transistors.
                Result is the same. about 5 min then humming popping and general terror starts.
                Any other thoughts?
                • jibber
                  • Mar 2014
                  • 8
                  I did not clean the glue off, what works well to assist that?
                    master hoarder
                    • May 2008
                    • 12164
                    Originally posted by jibber
                    Any other thoughts?
                    No idea, but it sounds like bad solder joints. (I know you checked them, but perhaps resolder some more - even those that don't appear bad)
                    As far as cleaning the glue... just a small sharp screwdriver, tweezers, cutters... really anything that can pry that stuff. Really no other way I know of to take it off. It's a big annoyance, I know! Older Bestec PC PSUs have it spilled everywhere in them and many here who have ventured to fix one will tell you how much they hate this stuff (myself included).
                    • pnwatlast
                      • Oct 2015
                      Hi, did you ever fix your Tss-450? How about those big caps--replaced?
                      • chaos-theory
                        Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                        by chaos-theory
                        I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                        Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                        03-14-2025, 05:37 PM
                      • vlady carp
                        Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
                        by vlady carp
                        Hello, colleagues!
                        I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
                        What I've done so far:
                        • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
                        • The original processor is beyond repair, and I wasn't able to extract the dump.
                        • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
                        01-16-2025, 02:08 AM
                      • arabex21
                        Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
                        by arabex21
                        Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
                        I have a problem with this configuration:
                        ASUS PRIME B450M-A
                        RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
                        When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
                        09-19-2024, 03:05 AM
                      • IamPritesh
                        Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
                        by IamPritesh
                        I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
                        Some very important points :
                        • Laptop does not auto starts after shutdown if adapter is connected.
                        • It will only auto start after shutdown if the laptop is in BATTERY only mode.
                        • I have tried replacing batteries with a known
                        • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
                        09-24-2021, 05:01 AM
                      • rumpumpel1
                        ThinkPad T490s only starts with battery
                        by rumpumpel1
                        I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
                        If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
                        If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off...
                        12-02-2024, 01:42 PM
