Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
    Some very important points :
    • Laptop does not auto starts after shutdown if adapter is connected.
    • It will only auto start after shutdown if the laptop is in BATTERY only mode.
    • I have tried replacing batteries with a known
    • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10 minutes, the laptop starts within a minute on its own.
    Board ID : vegas/turis 15341-1
    Model : Dell Inspiron 15 3000 series.
    Where should I concentrate ? Charging section, RTC or something else ? There is no physical damage in the board. No water damage.
  • mon2
    • 14619
    Re: Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
    If available, can you link the schematics?
    Disconnect the bootable media. Do you still get this auto reboot cycling?
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Schematic attached - This the closest I could find
      I have removed the HDD and tried to boot with LIVE ubuntu pen drive and it still auto starts. So its not windows 10 specific.
      • mon2
        • 14619
        Hi. Can you repost the schematic?
        • IamPritesh
          • Aug 2017
          • 356
          • India
          schematic
          • mon2
            • 14619
            Disconnect the trackpad (TP1) & power button cables (PWR1 connector). Test again.
            • IamPritesh
              • Aug 2017
              • 356
              • India
              Sorry for the late response. The laptop is back with us now soI just disconnected the Trackpad and Power button connection but it is still happening. Its pretty strange to be honest, not sure what is trigerring this automatic startup after shutdown.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Observe the enable signal on 3/5V dc-dc converter.(U4001) or just replace it and check again.
                • sundarkanini
                  • Aug 2017
                  • 155
                  • india
                  It's just bios problem only try new bios with correct generation clear me bios its 100% working and tell results
                  • Rofix
                    Problem Dell vegas/turis mlk kbl-r 17841-1 wx2rr
                    by Rofix
                    Hi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
                    04-24-2024, 03:48 AM
                  • aliiash
                    vegas/turis skl/kbl 15341-1 91n85 bios bin
                    by aliiash
                    Hi
                    I need to a tested bios file of laptop dell
                    board number : vegas/turis skl/kbl 15341-1 91n85
                    this is original file
                    04-26-2023, 12:59 PM
                  • chaos-theory
                    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                    by chaos-theory
                    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                    03-14-2025, 05:37 PM
                  • Retrocomputer
                    Dell Vostro 15 VEGAS/TURIS SKL/KBL 15341-1 short circuit
                    by Retrocomputer
                    Hi everybody,
                    I have a Dell Vostro laptop with the VEGAS/TURIS SKL/KBL 15341-1 motherboard. Without notice, the other day the laptop was dead and as soon as I plug the charger in, the LED on the charger itself shuts off, as if detecting a short circuit in the motherboard. Measuring on the board between + and - of the plug shows no evident shorts (readings are in the hundreds of kOhms). If I plug a bigger charger with a higher current limit, it will stay on and some chips get hot. Using a thermal IR camera, a couple of mosfets get hot (but, testing them, they are not shorted, I think they...
                    07-16-2021, 03:40 AM
                  • Jmine
                    Dell Vegas/Turis MLK KBL-R 17841-1 WX2RR
                    by Jmine
                    Hello guys,
                    I've got this motherboard with me that turns on when the charger is connected(without pressing the power button), the fan is fully spinning and it doesn't display anything. there is led flashing 3 amber 5 white. voltage readings are also weird, sorry I couldn't find the schematics for the board.
                    Voltages are as follows,
                    @ PL5301: 1.015V
                    @ PL4401: NO voltage
                    @ PL4501: 5.100V
                    @ PL4502: 3.408V
                    @ PL5101 near RTC: NO voltage
                    @ PL5001, PL4801 PL4802, PL4701: NO Voltages
                    Looking forward for your guidance...
                    02-20-2023, 03:13 AM
