ThinkPad T490s only starts with battery
  • rumpumpel1
    • Jul 2019
    • 162
    • germany
    I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
    If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
    If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off (power LED goes out). The USB-C monitor shows no image.
    If I connect the battery and power adapter, the Lenovo logo flashes briefly on the monitor after a while, but the final message does not appear as in the case of the battery. The USB meter only shows a few mA the whole time, so the battery is not being charged either.
    What could be the reason for this?
    schematisc and boardview can be found here:
  • mon2
    • 14662
    What is the voltage showing on your USB-C meter? Is it 20V or stuck @ 5V?
    20V is required for a normal boot cycle. 5V is the power on default by the power delivery (PD) adapter.
    • rumpumpel1
      • Jul 2019
      • 162
      • germany
      The voltage is 20V.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Spider28
        Thinkpad T490s No battery recognize
        by Spider28
        I just bought a new T490s battery. The Lenovo Diagnostic said no battery. Open check the battery socket from motherboard it shows no voltage should be 11-12V. The usb-c power adapter had 20v and the laptop came up with ac adapter plug in. What should I check next?
        02-16-2024, 07:33 PM
      • Grafnus
        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
        by Grafnus
        Hey there,
        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
        Specs:
        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
        • CPU, GPU, RAM work fine (not involved in the Problem)
        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
        Now I noticed...
        08-06-2025, 11:54 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
