I built this circuit in the hopes of boosting an antenna signal for digital TV reception and it does is the exact opposite, it literally cuts the signal in half. I've tried smaller in/out caps and eliminated the diodes at the input. I've checked the specs on the transistor and it should function at UHF frequencies. I am real rusty on transistor circuit design and was never all the good at it to start with. The input/output Z is supposed to be 50 ohms and I realize that my balun and digital box Z are 75 ohms but I'd expect it to at least boost the signal level enough to see an increase regardless of the mismatch.
VHF/UHF preamp ckt doesn't work
Tags: None
Re: VHF/UHF preamp ckt doesn't work
How are the components are being put together? Shortest legs as possible? Ground plane? a short length of trace or wire can have very high impedance at UHF.
http://www.electroschematics.com/447...nna-amplifier/
http://www.sentex.ca/~mec1995/circ/activant2.html
Do a lot of search how to build UHF amplifiers, RF is like a black art.Last edited by budm; 03-17-2014, 09:18 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Wow. Speedy response. Thanks BudThanks for the links.
I'll upload some pics later, my camera isn't here right now. I kept the leads a short as I could building it on a little RS project board and it's in an Altoids tin. The in/out leads are the longest, about 1" each but inside the tin. I worked in RF stuff for several years (long ago and forgotten most of it) and you're absolutely right, all kinds of mysterious things go on in RF. It gets pretty weird.Comment
I recall UHF being very picky about stray inductance and capacitance back when I was doing this sort of thing on a regular basis (most of my stuff was VHF/FM for audio only though I did build some UHF circuits for video/TV applications).
Are the two wires down the right-hand side of the board by design?
Also, losing the diodes was a good start, they'd have demodulated an AM signal (I've built AM receivers that consisted of just an L/C tuned circuit and a diode in the past)
Also, the cut-off frequency of the 2n2369 may be a little low? - I'm seeing it listed at 500MHz, US UHF band only starts at 470MHz (and goes up to 890)
The BSX20 appears to have a similar bandwidth.
This means the amp should be fine for VHF but not for UHF as you'll get unity gain or less.Comment
I don't know much about RF but protoboard looks like a bad way.
Most RF designs I have seen do it 'manhattan style' or with custom PCBs."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Elysarian:
The wire on extreme right is B+ and next is ground. I tired to match the layout to the schematic as closely as I could.
As I recall a diode in series would demod an RF signal, not sure about ganged like this, but the reason I removed them was due to their internal capacitance.
I think you're right about the transistor bandwidth and that's probably the biggest problem.
My previous exp was with 2-way VHF-FM gear and a little UHF thrown in too.
Agent24:
I'm not familiar with what "manhattan" style is. Is that like building things atop one another?Comment
Have you considered using a monolithic amplifier such as the Mini-Circuits MAR-6SM+ which covers DC to 2 GHz?Attached FilesComment
Yes I have and I thank you for the very good suggestion. I may do just that. I've ahd a little trouble finding a source for the MAR-6 though. I was curious as to why this design didn't work, at this point I am satisfied with the explanation that the bandwidth limit of the transistor is the big reason for it not working.
This is why I love this place, someone like me can bounce ideas off other minds and get good feedback. It's awesome. Thanks.Comment
You can find the MAR-6 and other Mini-Circuits parts at RFParts.
http://www.rfparts.com/minicircuits.htmlComment
Thank you very much indeed. Site bookmarked. I have a schem for using one and I'll see about getting the parts together for the project.Comment
I always like how it looks when done well, but I've never used it myself. I just make standard PCBs with KiCad.
I see many people use it for radio receivers, so I thought it might be suitable for your project - but I am not an expert in RF stuff so I could well be totally wrong!Attached FilesLast edited by Agent24; 03-19-2014, 03:52 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Steve, the output impedance of a common-emitter amplifier is roughly equal to the value of the collector resistor. In your case: 1.5kohms, which is way above 75 ohms. I believe this is why you are having so much loss. Also, check the DC collector voltage to see if the transistor is biased happy, say 1/2Vcc.
With RF amplifiers, usually you will see an output transformer or an added emitter-follower to provide the low output impedance.Comment
That's good info redwire, thank you. I will check the collector DC and try a smaller resistor on the collector.Comment
The collector voltage is about .3 volts lower than supply voltage. Sub'ing an 85 ohm in place of the 1.5K made no appreciable difference to the collector voltage. Tests were done with and without a 50 ohm resistor load on the output.Comment
The collector voltage is too high- the transistor is almost cutoff at 0.0002mA (=0.3V/1500) quiescent current instead of 6mA. It might be shot.
I can't see your resistor colour codes, but check with an ohmmeter if they are wrong.
Lowering the collector resistor will make it eat batteries or overheat the transistor, that's why an output transformer is used to match 75 ohm loads.
It's an art to do a good RF amp and I think this circuit is too basic a design to begin with, so I wouldn't ask too much of it...Comment
You cannot just change the Collector resistor without changing the bias resistors to get the VC to be at 1/2 VCC. AS redwire indicated, the circuit will draw more current also.
I.E: PS is 12V, Rl is 75 Ohms, so @ 1/2 VCC, you will have 6V across 75 Ohms which means the current through the resistor will be .08A (6V/75 Ohms) or 80mA. You will then calculate the Base current required to have Collector current of 80mA.Last edited by budm; 03-21-2014, 05:11 PM.Never stop learning
Thank you both for the info. This is where I am really rusty, get lost in the math, and forgot most of what little I knew and I never grasped it that well to begin with.
I know the amp design is cheap and dirty and the author said it is not perfect but said it does work, so I'm not expecting a lot out of it. However it is a learning experience for me and maybe it will sink in to my old brain, that's really the reason I keep playing with it.
I am looking at some better designs. I like the MAR6 amp and will probably try building an RF amp with that device. I know I could just buy an antenna booster but it's more fun to try making things and at least I can learn from it.
Edit: I did measure the resistors before using them and the actual values are correct.Last edited by SteveNielsen; 03-22-2014, 07:46 AM.Comment
As it says in the original article, the frequency range for that circuit is 14 to 550 MHz. So if you are trying to amplify UHF TV signals, then you need a transistor with a higher fT.
http://users.belgacom.net/hamradio/s...eband_MAR6.htm________________________________________________
Invisible airwaves crackle with lifeBright antennae bristle with the energy________________________________________________Comment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by dicky96Hi guys
I have this power transistor, it's taken from a Class G Power Amplifier. I already found two short circuit diodes on the Faulty Channel, but I decided to remove the other transistors and test them.
They all test OK but this one is marked B1186A and on my Peak DCA55 it analyzes as a PNP Digital Transistor (which I believe is a transistor with integral base resistor) but if it is a 2SB1186A then it should detect as a regular PNP Transistor.
Having said that I put it in my LCR-4T semiconductor analyzer and that just says it is a PNP Transistor.
by hollox123Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
1. Laptop keyboard doesn't work
2. The backlight on the laptop keyboard doesn't work
3. The x2 side LEDs (red) on the laptop don't work
The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
But I am strongly aiming that it is somehow a BIOS-related problem,... -
Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
Also fixed A LOT of cold solder joints and also done some modifications,...-
by resistor83hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
I tried updating the bios but the problem remains
https://s...1 Photo - Loading...
