B1186A Digital Transistor?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this power transistor, it's taken from a Class G Power Amplifier. I already found two short circuit diodes on the Faulty Channel, but I decided to remove the other transistors and test them.
    They all test OK but this one is marked B1186A and on my Peak DCA55 it analyzes as a PNP Digital Transistor (which I believe is a transistor with integral base resistor) but if it is a 2SB1186A then it should detect as a regular PNP Transistor.
    Having said that I put it in my LCR-4T semiconductor analyzer and that just says it is a PNP Transistor.
    So I am a bit uncertain if this actually is a (2S)B1186A and if it is definitely OK or faulty.
    Yeah I could desolder the one form the the other (working) channel but the amplifier modules take some effort to strip down and I would rather not have the hassle if I don't have to.
    You can see which device it is here - it's the one clipped to the front end of the heat sink you can see me checking it here:
    https://www.youtube.com/watch?v=kbPynpQefz8 (28mins 30secs)
    Follow me on YouTube
    Learn Electronics Repair
    • 31256
    Re: B1186A Digital Transistor?
    the logo looks like Rohm which makes it the 2sb part
    most "digital" pre-biased transistors contain 2 resistors anyway, not one.
    what does it look like on a multimeter diode-test?
    • R_J
      • 9607
      I agree, it is a Rohm 2SB1186A, Usually paired with a (NPN) 2SD1763A
      Most of the "digital transistors" I have seen are small case low power, not to220
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        OK thanks. I ordered a couple from Ali as I was placing another order anyway for the faulty diodes needed to fix this amplifier, plus an M2 adapter card for one of my PCs so combining the postage with other things, they only cost me 70 cents for two 2SB1186A
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
        • acedogblast
          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
          by acedogblast
          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
          03-01-2023, 08:24 PM
        • Francesc V.
          Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
          by Francesc V.
          Hi:
          I've realized that one of the channels of this amplifier has no proper sound.
          This is the signal at the speakers output.
          As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
          Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
          07-15-2025, 01:33 AM
          FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
          BOOST CONVERT CONTROL IC
          The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
          FP5139 FEATURES...
          10-07-2024, 05:15 AM
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
