Help with trying to fix phone that is not charging (Pics inside)
  • SluggerB
    • Aug 2020
    • 747
    • US
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone. I do not want to damage Old Phone any more. Right now the phone is usable but I have to charge batteries externally and swap them out every couple days. I would rather do that than risk ruining the device.
    The first thing I tried was a USB port swap. I removed the existing port on Old Phone and put a new port I had on it. I failed to realize at that time that the phone has a "reverse" micro USB port, and the port I put on was a standard one, so the cable was flipped upside down and the pins were reversed when inserted. I inserted the cable, and nothing happened at all. No charging sound, no notification, nothing. I ordered a new reverse USB port, and put that port on. Same thing, insert USB cable, and absolutely nothing happens. I am 100% sure the port swap is good, I check continuity between the pads where the legs connect and the ends of a USB cable and it showed continuous. I tried plugging the phone in a PC, also nothing, the phone is not recognized.
    I looked at the Old Phone board under a thermal camera with the cable plugged in, no components were getting warm
    The way the phone is designed is that the USB port is on one side of the board, but all the component are on the opposite side. The opposite side has test points corresponding to the USB pins. I checked voltages on the test pads, and on New Phone, I found 5V on one of the pads (See Pic). On Old Phone, 0V.
    How could I tell if that test point is where the USB leg come up from the other side of the board, or if the circuit runs through bunch of other components and then ends up at that test point? My thought is if the test point is the beginning of the charging circuit (so it went USB Cable > USB Port > Test Point > rest of phone) I could run a wire from the USB port leg to that test point and restore charging. But if it isn't, I would be bypassing potentially important parts of the charging circuit and could be sending power to the phone in a manner that could damage it. And how likely would it be for some sort of "internal trace" connecting the leg of the USB port to the test point to break? That's what leads me to believe the test point is at the end of the circuit and not the start. It also worries me that the phone is not recognized by a PC at all.
    Sorry about the blurry photos I will try and get some better ones off my microscope later
ID:	3327715 Click image for larger version
    • 31169
    start here - you may find a schematic!
    https://forum.gsmhosting.com/vbb/
    • SluggerB
      • Aug 2020
      • 747
      • US
      I tried registering lets see if it gets through
      • SluggerB
        • Aug 2020
        • 747
        • US
        Here is a much cleaner version of the back of the board.
        • SluggerB
          • Aug 2020
          • 747
          • US
          I did have one idea .... I could lift the leg that has 5V on it off the board on New Phone, then run a wire from that leg to the test point, and see what happens when I plug it in. If it charges, that would seem to indicate to me the test point is "next in line" for the circuit after the USB port pins. And if that is the case I could run jumper wires to all the test points and bypass the internal traces altogether. I'll try that tonight
          • truclacicr
            • Apr 2019
            • 335
            • australia
            https://www.prisemi.com/pdf/7jdbhejg...VSHC3N15VU.pdf
            A TVS diode can be removed from the circuit without affecting its function. There will be no overvoltage protection, though.
            • harp
              • Jun 2022
              • 619
              • Planet Earth
              Just be carefull while doing this bypass, allways limit current at first. Is it 0V because of broken track or is rail shorted to ground?
              Generally, the legs are very fragile...
              • petehall347
                • Jan 2015
                • 4434
                • United Kingdom
                see if tvs is shorted that is the failure mode
                • SluggerB
                  • Aug 2020
                  • 747
                  • US
                  You can say that again. After about 2 hours of trying I was unable to get wires connected to the port legs successfully. My soldering skills just aren't there yet.
                  • SluggerB
                    • Aug 2020
                    • 747
                    • US
                    I ordered up a pack of USB breakout boards, that will allow me to just run jumper wires from test point to test point and no longer have to fiddle with little pins. Will be here tommorow
                    • truclacicr
                      • Apr 2019
                      • 335
                      • australia
                      I have seen two different pinouts for USB 3.0 connectors (on the PCB side). I would confirm that 5V and Ground match up between PCB and the host-side pins.
                      https://pinoutguide.com/PortableDevi...r_pinout.shtml
                      • SluggerB
                        • Aug 2020
                        • 747
                        • US
                        These are Micro USB, but I will be doing a pin mapping exercise anyway since the phone has a reverse port but they don't sell reverse port breakout boards that I could find.
                        • dnytwaryors
                          • Aug 2023
                          • 53
                          • Philippines
                          Try to solder the jumper wire on pin 1 of micro usb and then the other side is in the pin 1 of battery connector or test point.
                          • Hondaman
                            Cold temperature battery damage?
                            by Hondaman
                            A couple of evenings ago, my cell phone spent 6-8 hours on the floor of my car, which was parked on the driveway. Probably at or below 0 Celsius. When I took the phone inside, it was turned off, and the battery was at 0 percent (Galaxy S10 Plus). I charged it (wirelessly) without letting it warm up (yes, I know that was probably a mistake -- I probably should have put the phone onto an electric blanket I have).
                            Now, when the battery reaches something like 72 percent or 75 percent, it charges normally. Below that point, it takes 90 minutes to add 10 percent to the phone's battery charge....
                            01-05-2025, 05:22 AM
                          • R7027
                            How to probe TP7002 for AP_PS_HOLD on SM-G930F?
                            by R7027
                            In the service manual for Galaxy S7 (SM-G930F), step number four in the flow chart for troubleshooting power-on issue is to check the voltage level of a "signal".
                            I had a very hard time locating this. I didn't understand what it means to check for voltage of something by its signal name, and it's location was not described in the service manual (not that I could see in my four chapter excerpt of the complete manual). Then I learned that this signal name needs to be translated into a test point (TP) ID on the board. This is unlikely to be referenced in a service...
                            01-02-2023, 06:25 AM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • keeney123
                            new OS on a Sonim XP5s phone
                            by keeney123
                            To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                            I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                            05-13-2022, 07:19 PM
                          • Thomasraud
                            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                            by Thomasraud
                            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                            QUOTED
                            -It works on charger (without battery connected-only charger)
                            -It works on battery (without charger connected-only battery)
                            -& it also works when plugged in battery & charger, but it's not charging the battery
                            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                            and..
                            QUOTE
                            The IC cannot maintain the input current level
                            06-28-2022, 06:47 PM
