    • Jul 2011
    • 6040
    Originally posted by redwire
    I don't see a main PWM control IC in there, but the two 27uF caps might be for the driver stage of a 1/2 bridge, they are to keep imbalance or maybe average current reasonable. They see action when the PSU is heavily loaded.
    Never seen a Marcon primary cap before 180uF 400V.
    Actually I did have a few 27uf @ 50 volts but they were in a container that is odd values or low voltage capacitors that I mainly use for 5 volt switching power supplies I did not even think about looking in this container because I was looking for some 3300uf @ 35 volt I have some but they are not brand name ones for this switching power supply but I am not going to change them because of the quality of these boards and that I had to do a repair job in four places
    • CapLeaker
      Leaking Member
      • 8184
      To date I have not figured out what the substance was. Almost like dried up FluidFilm. Weird. I also can't figure out why this “coating” was just in the power supply, And it was sucked in from the front. The 2 radios inside were clean as a whistle. If someone would have sprayed it from the front, it would have been all over the place inside.
      so this would really limit things.
      I did figure out the playing dead problem. It was the bigger ribbon cable that is between the TX radio and the front LED board. The ribbon cable chaffed down to the Ethernet cable that goes between the board on the front and a temperature control board on the back.
      Sorry sam_sam_sam I totally hijacked your thread.
        • Jul 2011
        • 6040
        I would not worry about that because I have been interested in your off topic about my endeavors about my Panasonic switching power supply that the circuit boards are crap and how you are trying to resolve your own issues with your experience with the substance in your switching power supply so it is not completely off topic
        • Agent24
          I see dead caps
          • Oct 2007
          • 4960
          • New Zealand
          Originally posted by stj
          27uf +20% for tolerance is 32.4uf
          just saying
          Ah, but what if your 33uF capacitor is also +20%....
          -David VanHorn
            • 31051
            never happens - ever
            i suspect caps are graded like leds and the good ones go to specific customers while the average ones go into the supply chain
            • Agent24
              I see dead caps
              • Oct 2007
              • 4960
              • New Zealand
              #26
              By that reasoning though, the original 27uF caps would never have been +20% either.
              So the circuit may well be unstable with something that much higher
              -David VanHorn
                • 31051
                well lets see the board
                  • Jul 2011
                  • 6040
                  In post # 9 I showed one side of the board but I am not going to remove it again because of how poor the soldering joint traces because I plan on reusing it for a project that I want to complete I am going to replace the output capacitors I just have not got to this part of the recapping process of this board yet
                  If I can take a better picture of this board I will post it
                  • redwire
                    • 3910
                    I think today they can manufacture electrolytic capacitors within a few % tolerance. It's not the 1950's anymore for the -20%/+80% number, and its +/-20% nowadays still a 40% wide window.
                    Many larger caps I've bought are at basically at -18% lol. An old cap is 82uF 450V, the new one measures ~70uF (happened several times) so I end up upsizing and buying 100uF to get 85uF. This is Chemicon and Nichicon. Why would you give the customer more than what the spec is
                    Smaller caps seem to be closer tolerance to rated value, so a 27uF would be very close to that.
                    Wild guess this is a half-bridge SMPS and the 27uF is part of the driver circuit, like in PC power supplies.
                      • Jul 2011
                      • 6040
                      These are the best pictures of the daughter board
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                        Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                        by sam_sam_sam
                        I was working on this CNC machine today found no keyboard functioning no control relay powering on
                        The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                        Found shorted diodes on main controller relays there are 3 of them that...
                        01-07-2023, 05:43 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
