I want to dim light bulb by 50% I want to learn how to calculate it on my own
This topic has been answered.
+ More Options
Posts
  • Omron
    • Mar 2023
    • 49
    • Serbia
    I have a 5W lamp on 12Volts battery, I want it to be half as bright, so I will add a resistor. What resistor should I supply?
    A = W = 5 = 0.416mA
    _ _
    V 12
    R = V = 12 = 28.84 Ohms (R) this is resistance of lamp
    _ _____
    I 0.416
    So I will add one resistor 28.84 Ohms
    I will have 28.84 + 28.84 = 57.6 Ohms
    Or 28.84 + 28.84 = 14.42 Ohms
    I don't know if it will work in series or in parallel
    voltage would be 6V and amp current mA = 0.208mA We divide everything by two
    W= V * I = 6 * 0.208 = 1.248Watts resistor would be needed and 28.84 Ohms
    Is my calculation correct? And I need explanation why its divided by two I'm little confused
  • Answer selected by Omron at 06-08-2024, 07:13 AM.
    momaka
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Your calculations are correct...
    The approximate resistance of light bulb will indeed be: P = V^2 / R... or R = V^2 / P = 12^2 / 5 = 144 / 5 = 28.8 Ohms.
    But here is where you got tricked: you probably assumed that if you use a 28.8 Ohm resistor in series with the bulb, the voltage going to the bulb will be divided in half (6V), which is CORRECT. However, the power usage of the bulb will not be divided in half...
    For pure resistive components, dropping the voltage in HALF (1/2) means their power usage will go down to a QUARTER - i.e. 1/4 of what it was.
    What's interesting is that you even found this with your own calculations, which showed that the bulb will be using 1.248 Watts, which is CORRECT again, as 1.25 Watts is 1/4 of 5 Watts.
    Now, to make the bulb use only HALF of its rated power (i.e. 2.5 Watts), you can use this formula P = I^2 * R, where we use 2.5 Watts for P and 28.8 Ohms for R to get the current, I, going through the bulb. So...
    I = sqrt(P / R )... or = (P / R )^0.5 = (2.5 / 28.8)^0.5 = (0.086805555)^0.5 = 0.29463 Amps
    Next, we calculate the voltage across the bulb with this current flowing through it. To do that, we simply use V = I * R = 0.29463 * 28.8 = 8.49 Volts
    Now, we still don't know the value of the resistance of the resistor to use, but we do know it has to pass approximately 0.295 Amps through it and there must be 12 - 8.49 = 3.51 Volts across it.
    So to get the value of the resistor we need, the following equation can be used again: R = V / I = 3.51 / 0.295 = 11.9 Ohms ... If you don't care to be driving the light bulb at *exactly* half of its rated power, then you can go up or down a bit on that resistance, so you can have an easier time finding a standard value resistor. In your case, both a 10 Ohm or a 12 Ohm resistor will give reasonably close results.
    But we are not done yet! There's one more calculation: to see how much power (heat) the resistor will dissipate. If you pick a resistor with too low of a power rating, it will burn out quickly.
    Here's how we calculate the power rating of the resistor: we already know the current going through it and we know its resistance (about 12 Ohms, so let's go with a 12 Ohm standard value).
    P = I^2 * R = 0.295^2 * 12 = 1.04 Watts .... so a 2 or a 3 Watt -rated resistor will be good to go (it will still run a little hot, though.)
    On the other hand, if you use a 10 Ohm resistor, you can't really use the above equation anymore, since the current won't be 0.295 Amps anymore. It will be a bit higher. But that's easy to calculate now:
    I = V / R = 12 / ( 10 + 28.8) = 12 / 38.8 = 0.3093 Amps
    The bulb will then use about P = I^2 * R = 0.3093^2 * 28.8 = 2.76 Watts
    And the 10 Ohm resistor will be dissipating about P = I^2 * R = 0.3093^2 * 10 = 0.95666 Watts... so a 2 or 3-Watt rated resistor will be needed again so it doesn't run as hot.
    Hope that was enough math for you for the day.
    Alternatively, just get one of those cheap $ step-down buck regulators found on eBay or AliExpress and turn down the voltage going to the bulb to whatever is needed to get the desired bulb brightness (or rather, dimming.)
    As harp noted above, half the output power doesn't necessarily translate to half of the output lumens - at least not for incandescent / halogen bulbs. So you will need to experiment a little too, to get the brightness / dimming you want.
    • Omron
      • Mar 2023
      • 49
      • Serbia
      https://ohmslawcalculator.com/voltag...der-calculator
      https://ohmslawcalculator.com/ohms-law-calculator
      By this calculator it seems like I calculated well and that resistor needs to be put in is indeed 28~ Ohms...Two resistors in parallel in fact so I have 14.4 Ohms~
      And about watts it would be
      Ampers = Watts = 5 = 0.83miliAmps
      _____ _
      Voltage 6
      Watts = Voltage * I (Ampers) = 6 * 0.83 = 4.98 watts
      So my resistors needs to be two resistors in parallel 28.8 Ohms each, which would give me 14.4 Ohms resistance and I need 5 watts resistors to be able to take this current... Need confirmation
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        the lamp resistance will change when its powered up .
        • harp
          • Jun 2022
          • 596
          • Planet Earth
          You are on wrong track, brightness is not linear with resistance.
          Say, if you have 100w lamp, and in series add one more 100w lamp, result of each one brightness is less than one single 50w lamp.
          • Omron
            • Mar 2023
            • 49
            • Serbia
            So what should I do?
              • 30963
              pwm control
              you can make a circuit with an 8pin chip and a mosfet or just buy a module designed for 12v motor/fan control from aliexpress for a $
              if you want to make one, the chip i would use is a 555 - read the datasheet to see how usefull it is!
              if you use a 555 and a fet you wont be burning lots of energy as heat, the circuit will just be switching the lamp very fast to control the brightness.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                you might be best to see how a 3w lamp looks
                • harp
                  • Jun 2022
                  • 596
                  • Planet Earth
                  The brightness of light (lumens) you can measure with some mobile aplication like light meter, so you have reference point on specific location, say table.
                  When that divide in half, that is what you need.
                  If the heat of resistors is not a problem, you can build a simple resistor network to experimentaly adjust needed value, and able to set it precisely, example in attachment. Do not use potenciometer if not rated for this aplication, or you are not sure about outcome.
                  The circuit with transistor (on heatsink) allow you to use ordinary low power potenciometer to control brightness, I guess that you want analog solution...
                  • Omron
                    • Mar 2023
                    • 49
                    • Serbia
                    Well I actually wanted to make this bulb dimmer, its shining into eyes during night, its on tractor vehicle, I thought that adding some sort of resistor would do the job, since bulb is sealed inside, I didn't wanted to take it apart and to put smaller one inside, but once it dies I will do it
                      • 30963
                      if its for a vehicle, just get a ReoStat
                      go to a scrapyard and you can find them on most old (older than 80's) cars
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        stick a sheet of lighting gel over it
                          • Jul 2011
                          • 6030
                          Or get a new car with a digital PWM controller that is made for 12 volt LEDs or incandescent light bulbs the majority of them work very well however you need to trace the wires of the circuit so you know how to hook it up correctly
                          • Omron
                            • Mar 2023
                            • 49
                            • Serbia
                            Well thx guys I think I have enough ideas now
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                                • Jul 2011
                                • 6030
                                Originally posted by momaka
                                —>Hope that was enough math for you for the day. <—
                                I always like reading your explanations of how to figure out ohms law calculations and how to troubleshoot devices keep up the good work
                                I have learned a lot from your posts
                                • Omron
                                  • Mar 2023
                                  • 49
                                  • Serbia
                                  Thank you momaka for explaining formulas to me, and to everyone else who was willing to help me.
                                  I will sit down with piece of paper and calculator and do all calculations by myself again, its easier to learn once you dip the paws in how they say hehe
                                  • Omron
                                    • Mar 2023
                                    • 49
                                    • Serbia
                                    I put it on paper, easier to calculate that way, by the way my notification lamp is connected at same fuse as my headlights and headlight switch.
                                    Of course it turns on lights when I turn on lights on machine, don't want it to be running notification light non stop without being able to switch them off of course..
                                    My question was what if I put like 5watt 12 Ohm rsistor? Will it do just as fine job as 3watt 12 Ohm resistor? maybe slightly better with heat dissipated?
                                    Also, since more lamps are connected in this circuit, will they affect my Current drawn etc, like we did calculus for one lamp, but do we need to take into consideration all lamps? like few more oil lamps and headlight notification lamp and also headlights rear lights, blinkers themselves, all in one circuit..
                                      • Jul 2011
                                      • 6030
                                      Yes if you want them to be dim as well otherwise no
                                      • Omron
                                        • Mar 2023
                                        • 49
                                        • Serbia
                                        I only want my notification bulb to be dimmed, so what do I do, maybe best option would be to switch lower watt bulb, it will draw less current and less lumens produced
                                          • Jul 2011
                                          • 6030
                                          Or higher working voltage light bulbs will also cause them to appear dimmer than a normal voltage bulb ran at the right voltage
                                          Here is an example let say a you have a 24 volt power source and you use a bulb rated for 28 volts is going to appear dimmer than a light bulb that is rated for 24 volts
                                          So let say that you were able to find an incandescent bulb that is rated for 18 volts or even 24 volts might work or it might be too dim
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • repair-it
                                            TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                            by repair-it
                                            I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                            Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                            10-11-2023, 07:18 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • ezenia
                                            LUMIMAN Smart Bulb IC ID?
                                            by ezenia
                                            I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                            In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                            04-28-2025, 05:56 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
