Joy of electronic flashlight very short lived
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Yesterday I received new Niteye MSA20 flashlight, added a pair of recently charged Eneloop AAs, and it worked fine
    That evening it would not turn on, appeared to be dead
    I tried a different pair of Eneloop, new from the packet, same result
    Also tried a new pair of Varta AA primary, you guessed it
    I should know better than be an early adopter of one of the new breed of double-AA powered LED flashlights
    But trying to work out what realistic options there are for rechargable CR123 equivalents is mind boggling (my mind anyway)
    Tempted to pull apart the elaborate tailcap switch, but better wait to hear what the vendor and/or manufacturer has to say
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Joy of electronic flashlight very short lived
    Batterys in the right way round?
    Can you test it without the tailcap switch.
    Only thing then left would be the Bulb?
    I think a RMA is in order.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Batteries were in the right way around
      And the tailcap isn't just a switch - it's got a little PCB inside, which presumably does the voltage shenanigans for the infinitely variable brightness
      But boy is my face red - I thought once the tailcap was removed, the rest of the flashlight was one piece, and its sparse instruction leaflet says warranty void if head is disassembled
      It's not one piece - once I unscrewed the head assembly, then re-tightened it to the body, everything worked again
      And this, of course, was after I contacted the eBay vendor
      Ah well, might help someone who stumbles across this thread after their MSA20 stops working
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Hey - we've all been there and I like a good easy fix.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          bet the board retaining ring in the head is loose.
          common in the cheap china lights.
          put a tiny bit of soft loctite on it when you tighten it.
          you can then easily open it back up for a led swap in the future.
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • adelfr2009
            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
            by adelfr2009
            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
            09-28-2025, 10:21 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
