Help identify this motor
  • mikey5791
    • 521
    • Malaysia
    Hi all forum members,
    Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
    Correct me if i am wrong on the initial test.
    Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything burning. Appreciate for any kind of hint or help.Click image for larger version
  • redwire
    • 3912
    It looks like a vacuum cleaner motor, like a home built-in type.
    These "universal motors" will run on AC or DC, you can apply even 12V and give it a spin.
    It will have thermal cutouts/fuses and I think should have continuity on the black wires unless they blew.
    • mikey5791
      • 521
      • Malaysia
      Thanks for the reply.
      Fyi, i applied 12vdc from a computer psu but it does not spin. Then i applied 12vac from a wall wart adapter, it does not spin either. Didn't see any thermal cutouts /fuses but i tested for continuity from the spade connector to the black wire and it has continuity. I did the same continuity test on the other spade connector to the other black wire and it has continuity too.
      Any other suggestions please kindly share.
      Thank you.
        • 31293
        the wires are the field coil because it doesnt have fixed magnets
        you need to also power the brushes - if they are still in it
        • mikey5791
          • 521
          • Malaysia
          How do i power the brushes? Fyi, i am clueless on which component are the brushes.
          • petehall347
            • Jan 2015
            • 4450
            • United Kingdom
            brushes rub on that shiny copper part . Click image for larger version
Name:	Screenshot from 2023-11-25 13-24-33.png
              • 31293
              it's a deceptive name, your looking for a pair of carbon blocks with springs behind them
              • redwire
                • 3912
                I don't see any carbon brushes or the holders for them. They must be missing, taken off.
                • mikey5791
                  • 521
                  • Malaysia
                  Yes, the carbon brushes or holders are confirmed missing. I used a string to measure the outer diameter of the shiny part (commutator) and it is about 10cm.
                  My next questions are:
                  1) Is it possible to get the right kind/size of carbon brushes with springs behind
                  2) Any item i can use to hold the carbon brushes or modded item as holder of the brushes
                  3) Is it possible to get this motor running after the first two issues are resolved?
                  Looking forward for any kind of help to get this motor working.
                    • 31293
                    unless the motor has some numbers on it to id it - very unlikely your getting it fixed.
                    what your looking for are brass (usually) tubes with the sprung carbon block in it and a plastic mounting of some kind - so it doesnt short to the frame
                    https://yt.artemislena.eu/watch?v=PfnRiB6ZFwA
                    • redwire
                      • 3912
                      You can search for "vacuum cleaner motor" and find one that matches what you have for looks (image results). It will be used in several different makes/models i.e. Ametek Lamb and look on eBay.
                      Brushes and holders and brackets/screws will cost a lot, so I would abandon the project. You don't know if the stator and rotor work (shorted turns) and the thermal fuses are in the braided spaghetti sleeves if they are OK.
                      • mikey5791
                        • 521
                        • Malaysia
                        Thanks for all the help and suggestions received so far. It is very likely i will abandon this project to revive the motor due to the cost of finding brushes and holders unless i come across the same motor again.
                        However, i gained more knowledge on "vacuum cleaner motor" and its related component which will be useful if i ever encounter another similar incident.
                        • juergenb
                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                          by juergenb
                          i am asking for some Help.
                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                          So i got a few of these from Banggood.
                          I swapped the motor and now i have a new fault condition.
                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                          If you press longer it will light blue and just mixup the milk.
                          With the new Motor it just starts...
                          03-23-2021, 11:24 AM
                        • SolomonMan
                          Electric Motor Question....
                          by SolomonMan
                          All,
                          Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
                          In the afternoon I noticed it was not running any longer.
                          During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
                          No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
                          I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
                          10-29-2023, 08:02 AM
                        • sbt123
                          charnwood w821 mini wood lathe motor problem
                          by sbt123
                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                          10-27-2024, 03:43 AM
                        • grimacelord
                          Component Identification
                          by grimacelord
                          Hello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
                          The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
                          The problem is finding a replacement component....
                          06-10-2025, 02:00 PM
                        • Per Hansson
                          Motor run capacitor physical size vs voltage rating & measurements?
                          by Per Hansson
                          (TL;DR skip the first paragraph)
                          I encountered my first dead motor run capacitor at a customer this week.
                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                          (Unless a servo motor makes more sense that is).
                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                          The pump would run but sometimes trip the 10A breaker.
                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                          Then it could...
                          09-20-2020, 06:32 AM
