Component Identification
  • grimacelord
    • Jan 2017
    • 383
    Hello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
    The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
    The problem is finding a replacement component. It appears to be a MOSFET, but searching it's imprint numbers/letters didn't come up with anything. I am not familiar with the component manufacturer logo on this component either, so I am not even sure who makes it. I will attach a few pictures and hopefully that is enough for someone to help me figure out what this component is or at the very least, what a good replacement would be.
    Thank you.
    Marking: D4013
    GA3A11
    Pin Count: 5 (4 leads and 1 plane)
    *All 4 leads are independent of one another. They do not share continuity with any other pin. The large plane is connected to a coil inductor which is then connected to an identical component as this one on the other side of that inductor. I have attached close up pictures to show where this component went and the traces show how the pins are not interconnected with one another.
  • lotas
    • Jan 2016
    • 4876
    • Russia
    Maybe something from this series https://www.muhua.com.tw/en/product/mosfet/to252-4
    Same as AOD609, AOD606 TO-252-4L (Complementary Enhancement Mode Field Effect Transistor)
    • R_J
      • Jun 2012
      • 9624
      That is what I would suggest as well, similar to SemiOne PE4025KC 40v, 16A, rds 18mΩ, there are many similar dual mosfets, this one is likely some Chinese brand.
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        I guess that is something simmilar to this (attach)... 4012... letters can varry from manufacture but numbers are close to wanted... you know for sure there is dual mosfet, and you can test it by transistor tester to confirm closest spec...
          • 31289
          the inductor near it makes it look like a buck or boost convertor though.
          • grimacelord
            • Jan 2017
            • 383
            Thank you for the replies everyone. I posted this exact question at numerous places so I could get as much exposure as possible. I figured I'd post some of the responses I have received at other places to see if it gets any ideas going about what I am working with here. I unfortunately haven't gotten any closer to figuring out what exactly this component is.
            Here are some other responses (hopefully it helps)
            First of all, we need to identify the manufacturer by the logo.
            If we can't determine it, you need to draw a diagram and determine the functional purpose of this element.
            Maybe I'm wrong, but I assume that this is a DC-DC Converter.
            For example, like this:
            Click image for larger version  Name:	24f3c870c3c38c87b395c77fa38e9dfeafbe08d1.png Views:	0 Size:	167.9 KB ID:	3656973
            I saw the inductor in close proximity and the part definitely gives me DC to DC Switching Regulator vibes.
            I looked pretty hard to find that semiconductor logo and haven't been able to find anything yet.
            Some sort of integrated half-bridge driver would be my guess. It appears that each of the two receive power and ground, with the output passing through a common-mode choke to the connector.
            For what it's worth, when I was using ChatGPT to try and help me identify this, it was suggesting that it appeared to be a synchronous buck converter circuit…
            Thank you guys so much for the help so far. Hopefully we can narrow this down!
            EDIT: Also, the pin marked Pin #1 on the board where the component goes does appear to be GND if that helps.​
            • R_J
              • Jun 2012
              • 9624
              Draw out the motor drive circuit, if it is used to control the motor and its direction, it is not likely a regulator ic.
              • lotas
                • Jan 2016
                • 4876
                • Russia
                But this is not an inductor, but rather a sound buzzer (polarity "+")
                • harp
                  • Jun 2022
                  • 648
                  • Planet Earth
                  Mayby some sort of h-bridge to control way of rotation...
                    Corsair CX750M [Model 75-002019] - burned output toroid inductor
                    by momaka
                    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                    09-19-2021, 08:44 PM
                  • Bartoloni
                    Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                    by Bartoloni
                    Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                    everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                    there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                    replaced the capacitor (330) and the inductor (R15) without any change
                    any idea? very thank you!
                    input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                    12-09-2024, 12:42 PM
                  • badcap111
                    How to read inductor specs?
                    by badcap111
                    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
                    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
                    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
                    09-12-2023, 01:25 PM
                  • slybunda
                    Damaged GPU Inductor Query
                    by slybunda
                    Hey all, iv got a graphics card ( Nvidia RTX A1000) it has a chipped inductor on it. Now the card seems to work perfectly fine with no issues so i get the feeling i should just leave it be and carry on using it but to be on the safe side i would like to keep a spare inductor in stock incase i feel like replacing it one day.
                    Any one know which part number i should get? the pics show it to be a 1R0 but not sure on package size etc. RS components is close by to me and my preferred place to go for genuine electronics stuff.
                    10-01-2025, 02:27 PM
                  • rashidjafar
                    Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                    by rashidjafar
                    I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                    Values for :-
                    PC43 : Capacitor [3x1.5mm]
                    PL7 : Inductor [2x1mm]
                    PC39 : Capacitor [1x0.5mm]
                    Any ideas would be appreciated.
                    I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                    08-07-2025, 05:10 PM
