Has any one used this ESR meter
Tags: None
Re: Has any one used this ESR meter
It's a very expensive clone of an oooold esr meter.. i forget now the name.
Not worth the money - for that amount you can get a complete LCR meter with ESR measurement capability.
ps. my memory may fail me, i may be thinking of another similar design and it could be just a clone of this BK Precision 881 meter: http://www.amazon.com/Precision-881-..._sim_sbs_hi_10
BK Precision may have purchased the design from a company - they oem a lot of their products.Last edited by mariushm; 11-23-2013, 05:55 PM. -
This tester has DCR method before measure the ESR. that is the different from others as I have ever read. But this is EXPENSIVE for hobbyist
"There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... -
by sam_sam_samAre these ESR capacitor tester any good
https://www.ebay.com/itm/29436085379...cAAOSwavphKIy4
Or this one
https://www.ebay.com/itm/22354281634...732cd4e55be8d6... - Loading...
