ESR Capacitor Tester Ohm Meter Measuring Internal Resistance of Capacitor R1L4
    • Jul 2011
    • 6070
    Are these ESR capacitor tester any good
    https://www.ebay.com/itm/29436085379...cAAOSwavphKIy4
    Or this one
    https://www.ebay.com/itm/22354281634...id=28039177231
  • gette
    • Jun 2021
    • 5
    Re: ESR Capacitor Tester Ohm Meter Measuring Internal Resistance of Capacitor R1L4
    To answer your question I am not sure. And I don't know anything, yet. lol
    But JIC my 2 cents helps someone... I researched those and others a lot. But ultimately decided on paying double the price on a DER DE-5000 LCR which appears to be heads and tails better with glowing reviews and much more accurate (as well as adjustable and many more features).
    If your not in a hurry you can get them from overseas for less then $100.
    I know double the price, but I figured if it helps this noob catch something the other would have missed due the being much more accurate and adjustable/features then it will be worth it to me.
    Now I just need to learn how to use it and learn how to proceed on my first LCD TV PSU troubleshoot/repair! lol I posted but no help yet. lol
    Good luck sir!
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      check out maybe the Bside ESR02 pro. Same league... it does a fairly decent job, but it does not as good as my Agilent.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • expertreader
        Dell 5520 not booting up - on light comes on momentarily
        by expertreader
        Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
        Hi all, looking for some help to get started on troubleshooting without schematics
        I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
        I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
        • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
        • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
        • i have measured 16.5V available at the capacitor
        10-19-2025, 08:20 PM
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
      • Gentian
        Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
        by Gentian
        I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
        09-27-2025, 11:03 PM
