Bipolar Disc Caps
  • pentium
    • Mar 2006
    • 2778
    Bipolar Disc Caps
    ....I swear I made this thread already...
    Anyways, I bought a CDV-700 geiger counter off ebay and ended up getting it free because it has a problem.
    When turned on it works fine and all for a few minutes, then the high voltage dies and the tube loses power. Turn it off, wait a minute and switch it back on. You get it briefly.
    Anyways, something seems to be not happy that it's warmed up. I'm immediately suspecting the capacitors.
    Aside from C2 which is a 3v 400uf axial for the meter and C3 which is part of the clicker circuit I'm looking at C1, C4 and C5 which are ceramic disc capacitors. So I replaced those and now I get no high voltage at all. Put the old caps back in....no high voltage with those now too, wtf?
    (my replacement caps are the ones at the bottom)
    Looking at the schematic these capacitors are polarized...but they're discs. They shouldn't be polarized....are they?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    Re: Bipolar Disc Caps
    They are non-polar high voltage ceramic disc. The high voltage power supply is very high Z circuit, so did you clean the board real well for any residue, etc.? HV is generated by T2, CR5, Q2 free-running Osc circuit. Is the transistor Germanium type? R7B has any affect when adjusted?
    • redwire
      • 3912
      Does the HV oscillator run? I would suspect the transistors, they are probably old PNP germanium types 2N404? R7B sets the HV oscillator drive, so twiddle it to see if the oscillator starts up. I'm not sure how to calibrate it, perhaps measuring current drain or the HV.
      V2 is a shunt regulator gas-tube, but the GV3A comes in different voltages i.e. GV3A-900 is 900VDC.
      Found more info on the CD V-700 here:
      http://www.eevblog.com/forum/project...the-waveforms/
      http://www.anythingradioactive.com/partsstore.htm
      • pentium
        • Mar 2006
        • 2778
        God dammit I fell for it again!
        After marking the position of R7B I gave it a few twists back and fourth with contact cleaner and High Voltage returned and stayed.
        Everything is good now. Also, thanks for confirming that they were non-polar.
        Find Nedry!
          Glad to hear it is simple fix.
          • Longbow
            • Jun 2011
            • 623
            A few comments: it was the convention to draw any type of capacitor using one straight line and one curved line. Usually the curved line represented the most negative point. On paper or film capacitors, the curved line represented the outside foil, so the capacitor can be positioned safely. Those capacitors still use a black line near one end to indicate outside foil. This drawing uses the earlier convention, except gets it wrong on the 400 uF capacitor.
            You say you immediately suspected capacitors as the problem. Aside from one electrolytic, there would be no reason to think that a handful of ceramic capacitors are your most likely failures. Only one type of capacitor is polarized. Electrolytics are in effect small batteries with battery acid between the plates. That's why polarity matters with electrolytics.
            A unit from this era shows the common use of PNP germanium transistors. Many designs mounted the transistors in tiny sockets, since the designers didn't know what the expected life span would be. They also thought that soldering the transistor would ruin it. There weren't many pencil soldering irons at that time, so a 300 watt Weller would do some damage. But there are lots of units out there with the original transistors that still work fine. Germanium still has its uses. Just look at the 1N34 diode which is commonly used in RF detectors.
            Is it plugged in?
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              Batteries use the chemical action of an electrolyte to allow ions to conduct between its plates. Electrons do not move internally between the plates of a capacitor. There is an insulator between the plates. There are five "parts" to an electrolytic capacitor: the anode foil, which is pure aluminum, and has been etched to increase its surface area; the cathode foil, which is pure aluminum and not etched; the aluminum oxide layer that has been formed on the anode foil, and is the dielectric; the electrolyte, which is conductive (highly!) and can maintain conformal contact with the etched and formed anode foil and with the cathode foil; the paper, which keeps the electrolyte in contact with the full length and breadth of the anode and cathode foils. Thus, the purpose of the electrolyte is to be a conductor, not to act chemically on the plates; the electrolyte is, effectively, part of the cathode of an electrolytic capacitor.
              PeteS in CA
              • redwire
                • 3912
                Longbow, I find 1960's germanium transistors not very reliable, due to their construction. Example: the 2N404 is an alloy-junction beast.
                I find leakage current and noise go up, beta drops and then they are dead. A bunch have died sitting in my parts drawers.
                • Longbow
                  • Jun 2011
                  • 623
                  Yes, thank you for the complete explanation of how electrolytics work. I like to refer to them as small batteries for humor's sake, and the fact that they are similar in some ways to batteries.
                  Is it plugged in?
                  • m4a2t0t
                    Disc caps
                    by m4a2t0t
                    Can I replace a ceramic disc cap with a multilayer ceramic cap? I cant even find .047 uf disc caps at digikey, mouser or newark. The places I do find them want anywhere from 25c to $3 each, at any quantity, plus shipping....
                    01-18-2024, 10:00 PM
                  • clearchris
                    New capacitor technology - high lifetime caps
                    by clearchris
                    I'm getting ready to put in a capacitor order. I generally look for nichicon, panny, kemet, or united chemicon, and I'm noticing that there aren't any 1000 hour caps anymore, and not many 2000 hour caps. Most of the caps are rated around 5000 hours or better. Last time I ordered, 1000 hour caps were pretty much most of them, and the very few 10,000 hour caps had pretty bad specs.
                    So what's the deal, have we made major progress with capacitor reliability in the past few years? Are these high lifetime caps ok to use? It's not that I wouldn't welcome the change, I really would, I'm...
                    03-26-2021, 06:39 PM
                    by momaka
                    03-15-2023, 10:17 PM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • link626
                    damn. I'm disappointed these high quality caps made my power supply worse
                    by link626
                    I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
                    But today it caused my tv to have a flickering spasm again.
                    what a letdown.
                    I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
                    Sometimes these high quality caps just don't make things better.
                    09-01-2021, 11:02 AM
