That 60W-equivalent LED: What you don’t know, and what no one will tell you
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: That 60W-equivalent LED: What you don't know, and what no one will tell you
    Same here, even if the ballasts sound like the Family Feud buzzer!
    In Springfield, they're now usually only on private properties! Because of the LED crusade of 2012.
    (2013 for most other towns that got LED street lights in Vermont.)
    -> Me thinks, are Rutland and Ludlow the only cities left in Vermont that still have the metal vapor lights for the majority???
    Go over the border to New Hampshire, things are majorly different! It looks like heaven for metal vapor light lovers!
    If you hate LEDs, New Hampshire will give you relief!
    And apparently looking more friendly for jobs, too ATM...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      i have a MH lamp outside my window and that thing is at the perfect angle to light up my valve radio collection. get all of them going at the same time at night and its so beautiful that a picture wouldn't do it justice!
      Follow the white rabbit.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Originally posted by kaboom
        I made this 150W MH "portable" thing with a parabolic reflector and ballast mounted on a base. A bit clunky, yet totally self contained.
        Let's just say it kept me from "going mad" in this basement with abysmal lighting I was doing work in. I'd almost say it was pleasant because of such wonderful lighting.
        We are like basil! LOL! The basil plants probably would droop with crap lighting...
        Basil seems to heavily crave incandescent lights!
        Perhaps we are like flowers too, LOL.
        I hear that flowers bloom more with sodium vapor lights. I wouldn't be surprised if they would bloom more with a metal halide like yours...
        I think I saw some fixtures of either type in a greenhouse.
        Arc A770 16 GB
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          Kind of funny, normally I couldn't care less about color rendition index, but I noticed under certain lighting, reading resistor bands is quite hard...
          Now I care!
          • Elysarian
            • Mar 2013
            • 200
            • United Kingdom
            metal halide lamps are used extensively in hydroponics set-ups, I know this partly due to the hardware pulled out of a marijuana farm in a warehouse unit my father in law was leasing out to some erm "eastern gents" (they claimed to be storing clothing there but a neighbour got suspicious of the fact that no vehicles ever visited the place for months)
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #26
              and anybody in denver could tell you that too. especially me! i fix the newer digital ballasts and my friend mike the HVAC guy specialises in grow-ops.
                by momaka
                03-12-2025, 03:42 PM
              • valvashon
                Insignia NS-LCD19-09 (third and final post, hopefully!)
                by valvashon
                I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                10-22-2025, 12:33 PM
              • Cornboats
                Bench inspection lamp- replacing with LED
                by Cornboats
                Decided to change broken flourescent ring with an led alternative bought off Ebay. It came without any details of required supply. The supplier
                does not have this information, just that its been stored in warehouse for 10 years. I want as bright a light as possible but am concerned that at too high a voltage will burn out the led's.
                There are 90 led's each with a small yellow spot in the centre of the inside of each led lens. Could these be mains tolerant led's. I've put 9-14v DC on the circuit and lamps glow but not to their full luminance. How much voltage can I apply without fear...
                08-25-2024, 02:50 AM
              • angelos
                Sinotec LCD TV Model ST-42KC42F "CCFL lamps not switching on"
                by angelos
                Hi Guys,
                It's been a while that i have been active on the forum, sorry for that. My primary job has been keeping me quite busy.
                The above set starts up with sound working just fine but the CCFL lamps (Inverter) runs for one second and switches off.
                My 24V supply is steady and the ON/OFF pin to the inverter is at +5V.
                The only thing i see is the PWM signal pin is at +5V without any square wave being emitted. Is this normal? as far as i can remember there needs to be a square wave pulse there. Am i right?
                I will now measure with my oscilloscope probe on...
                06-11-2023, 02:14 AM
              • Uranium-235
                Customer with SS AMP not used in years
                by Uranium-235
                He has a pioneer SA 608, matching Tuner (TS 608) and Tape deck (CT F600) and a pointless timer (DT 400)...late 70's early 80's from my research
                We're going to try to focus this as a Turntable setup (his turntable is a seemingly cheapo from like 10 years ago...but it does have a phono out), which is at least comforting because the amp has a phono input. It also had a USB port, looks pretty cheap
                I'm trying to go for an all analog here. What is the likely problematic caps? Power? I've never dealt with amps this old and of this type. I replaced them in a cheap yamaha...
                10-07-2021, 07:55 PM
