That 60W-equivalent LED: What you don’t know, and what no one will tell you
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
Re: That 60W-equivalent LED: What you don't know, and what no one will tell you
i have a MH lamp outside my window and that thing is at the perfect angle to light up my valve radio collection. get all of them going at the same time at night and its so beautiful that a picture wouldn't do it justice!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
I made this 150W MH "portable" thing with a parabolic reflector and ballast mounted on a base. A bit clunky, yet totally self contained.
Let's just say it kept me from "going mad" in this basement with abysmal lighting I was doing work in. I'd almost say it was pleasant because of such wonderful lighting.
Basil seems to heavily crave incandescent lights!
Perhaps we are like flowers too, LOL.
I hear that flowers bloom more with sodium vapor lights. I wouldn't be surprised if they would bloom more with a metal halide like yours...
I think I saw some fixtures of either type in a greenhouse.Last edited by RJARRRPCGP; 02-12-2014, 12:44 AM.ASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
We are like basil! LOL! The basil plants probably would droop with crap lighting...
I think I saw some fixtures of either type in a greenhouse.Comment
metal halide lamps are used extensively in hydroponics set-ups, I know this partly due to the hardware pulled out of a marijuana farm in a warehouse unit my father in law was leasing out to some erm "eastern gents" (they claimed to be storing clothing there but a neighbour got suspicious of the fact that no vehicles ever visited the place for months)Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
This is the zombie UN55NU6900F I wrote about in this original post.
It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
1. What could cause the standby voltage to be 1V higher than expected
2. Is this a problem
3. Could it have led to the failure at RM819, or was that... -
by samoelecDisclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
The power supply board is exactly the same from this post so I'll just steal it for now.
I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...-
by PedroGG90Hi everybody.
I have two 3 phase 400 vac smps siemens sitop 24 vdc giving red light overload and higher output 33 vdc.
The switching is controlled from micro controller.
Is it micro controller or transformer ? Or else pls ,?...Badcaps Electronics Repair Forum & Schematic Search -
by CornboatsDecided to change broken flourescent ring with an led alternative bought off Ebay. It came without any details of required supply. The supplier
does not have this information, just that its been stored in warehouse for 10 years. I want as bright a light as possible but am concerned that at too high a voltage will burn out the led's.
There are 90 led's each with a small yellow spot in the centre of the inside of each led lens. Could these be mains tolerant led's. I've put 9-14v DC on the circuit and lamps glow but not to their full luminance. How much voltage can I apply without fear... - Loading...
