Best ESR meter/What to look for
  • vhr
    • Aug 2012
    • 21
    • Russia
    #81
    Re: Best ESR meter/What to look for
    Polystyrene film capacitor 0,5uF/250v 0,5%
    http://img844.*************/img844/7267/ar6m.gif
    • LLLlllou
      • May 2011
      • 201
      Originally posted by Topcat
      Ohh for the love of punching infants
      I though I was the only one who found that enjoyable.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        #83
        The all topic is enjoyable.
        It represents the constant battle between different generations of people. LOL
        • ivtec
          • Dec 2008
          • 1967
          Originally posted by Misterkeeks
          So what? If it works, which ivtec say it does, than why bother to get a more expensive one on some list? It does not matter.
          My capAnalyzer 88A can't measure any thing lower 104 - 0.1 microfarad
          • chth96
            by chth96
            03-09-2024, 10:03 PM
            12-31-2023, 06:04 AM
          • jorpec
            by jorpec
            Hi
            Thnaks
            01-23-2023, 10:37 AM
            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
            12-14-2023, 07:45 PM
          • Stephan Mathers
            EDMI ATLAS MK10 Electronic Meter Discussion
            by Stephan Mathers
            Greetings, new guy here but always interested in the crazy universe of modding
            We just finished construction of around 25 vacation houses, all inside the same private area.
            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
            05-20-2025, 09:09 AM
