Replacing FETs
  • spleenharvester
    • Mar 2010
    • 921
    Replacing FETs
    What wattage soldering iron should be used for replacing SOP8 FETs?
    Every single one I've tried to replace with my 40W or 15W irons has just resulted in lifted pads. I've always had to heatgun it, but obviously that comes with its risks.
    The way I do it is, flux all the legs, slide a sewing needle under one side, and melt the solder - lifting all the legs on that side. One of them always pulls the PCB off with it!
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • mariushm
    • May 2011
    • 3799
    Re: Replacing FETs
    Liquid flux, add solder, liquid flux, solder wick, put solder iron on solder wick and suck solder in the wick. DO NOT DRAG the solder wick or drag the solder iron tip on the wick.
    A 60w iron will be fine. Maybe even lower wattage will work fine.
      master hoarder
      • May 2008
      • 12175
      Re: Replacing FETs
      It's much easier if you use 2 irons at the same time. If one of them is temperature controlled soldering station, even better. And if you have 2 temp-controlled soldering stations, you can desolder almost anything you want.
      The method is simple. Flux both sides of the MOSFET, add plenty of solder so that all of the pins are covered on each side. Add a bit more flux again. Then use the two irons to heat the MOSFET from both sides and lift or slide away the MOSFET. It's nearly impossible to damage the board this way. The only thing to watch out for is if you slide the MOSFET, make sure not to slide it into nearby SMD components, because they get desoldered too. Normally what I do before removing a MOSFET is take a picture of the board where it is located if there are a lot of small SMD components. That way, if one gets desoldered and lost, I can replace it. So far, that hasn't happened, though.
      • dj_ricoh
        • 2073
        • uk
        Re: Replacing FETs
        What? 2? one its ok but it needs to be good and a large tip.
        whats wrong with hot air ?if got a crap air gun that has a ventilator near the resistance yes! thats crap and you won`t be able to work with.
        With compressor in the station; thats a good station. starting from gordak... how about that even they got a good soldering iron on that station with removable tip ... my first station.
          master hoarder
          • May 2008
          • 12175
          Re: Replacing FETs
          I have hot air too. But I still prefer 2 irons since it's much faster and if there are capacitors around the MOSFETs, I don't have to remove the caps.
          • klangsotan
            • Mar 2014
            • 45
            • indonesia
            Re: Replacing FETs
            hai sir i have problem mosfet similarly where can i find link about that ?
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • ktmmotocross
              recommend good solder wick on aliexpress
              by ktmmotocross
              I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
              02-08-2024, 12:48 AM
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
            • petemanuk
              BGA solder balls not connecting - help pls
              by petemanuk
              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
              11-16-2022, 05:21 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
