Series light bulb trick
  • neuron
    • Feb 2013
    • 126
    • Portugal
    I'm using with success the "Series light bulb trick" in many circuits - troubleshooting.
    And have 15, 25, 40, 60, 100 W - incandescent light bulbs.
    But "Governments around the world have passed measures to phase out incandescent light bulbs for general lighting in favor of more energy-efficient lighting alternatives" in http://en.wikipedia.org/wiki/Phase-o...nt_light_bulbs
    It's possible use LED or Economic light bulb?
    Or other Variac ... idea ?
    Best Regards,
    Ruy
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Series light bulb trick
    large 1-3Kw heater is what i use.
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      The halogen bulbs, which are not yet on the ban list, can also be used. If all else fails, an appropriate resistor works fine too... Granted, getting a 60W resistor can be quite expensive.
      • mariushm
        • May 2011
        • 3799
        60w or lower regular incandescent lightbulbs can still be sold.
        There are halogen based incandescent lighbulbs that can be sold today because they're eating 40-60w but producing the equivalent of about 75 watts.
        There are 100w, 250w, 300w, 500w tungsten/halogen bulbs used for illuminating exteriors of buildings, like this for example:
        http://www.amazon.com/Sylvania-58887...s=halogen+bulb
        http://www.amazon.com/GE-Quartz-300-...s=halogen+bulb
        20w or lower lightbulbs will continue to be sold legally for bed lamps and stuff like that, so you could put 4-5 in series if you have to.
        I think you'll be just fine.
        • neuron
          • Feb 2013
          • 126
          • Portugal
          Thank you very much for all your comments mariushm, eccerr0r.
          I can use the halogen and the effect is the same.
          I have a LCR and in AUTO mode the incandescent, halogen give R.
          But the economic C.
          The procedure is: the halogen is mark 55W ( lumens, candle - 60 W). We use the 55 W to measure the R.
          goontron - I don't understand your info ... 3KW ... I don't need to power a car
          Best regards,
          Ruy
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            In the uk you can still buy 40w 60w and 100w relector light bulbs
            maybe only in edison screw fitting
            http://cpc.farnell.com/sylvania/0015...-es/dp/LP00966
            Or "Rough Service" bulbs
            http://cpc.farnell.com/ge-lighting/0...-bb45-00001003
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Best regards,
              Ruy
              1-3Kw = 1000 to 3000 watts
              that's the wattage of the heater that is my replacement for the old bulb trick.
              • neuron
                • Feb 2013
                • 126
                • Portugal
                Thanks,
                goontron - Can you detail your info ... I don't understand.
                I'm trying to limit the current!!!!!!!!!!!!! ... with your 3KW ... we have a short circuit again.
                Best regards,
                Ruy
                • japlytic
                  • Oct 2005
                  • 2086
                  I've used AC-rated capacitors for motor starting/running as a replacment for series limiters (generates no heat), since I learned that capacitors can be reactive components depending on frequency.
                  An AC voltmeter can be used between the Live input from the mains and the Live output to the load, and therefore, the AC voltmeter can be used as a "brightness" indicator.
                  As far as I know, halogen lamps can have undesirable characteristics for series limiters.
                    The reason for using the incadescent lamp is that when the lamp does not light up the resistance is low, when it lights up, the resistance can be as high as 10X the cold resistance, so it is like having automatic variable resistance in series with the load, when the load draws too much the lamp will automatically reduce the current. You want that cold/hot resistance function and also as an indicator. Use this method since the 70's. My set up has two lamp sockets and bypass switch.
                    http://s807.photobucket.com/user/bud...tml?sort=3&o=0
                      BTW: I checked
                      100W 120V lamp cold resistance is 10 Ohms, so current draw at start up is 12A, then drop down to 0.833A after the lamp is fully lit.
                      200W 120V is 5 Ohms.
                      • neuron
                        • Feb 2013
                        • 126
                        • Portugal
                        Instead of incandescent light?
                        Can you detail where I put the Cap (brand and type of motors??????) or AC voltmeter
                        F 220V - > Ac Voltmeter -> circuit with short?
                        N ____________________________________
                        Originally posted by budm
                        BTW: I checked
                        But I use 100 W to power a TV and we need 1,..A or 2A to power ... if you get 0.833A ...????
                        Best regards,
                        Ruy
                          0.833A is the maximum current it will allow to flow through the load. The purpose of the lamp is to help indicating if the Power supply has shorted circuit, you will not be running the TV with lamp in place. When I work on Monitor, I use 75W for up to 22inch, you will see the lamp flash bright for seconds then dims down.
                          For TV I start with 75W first to see if the standby power SUPPLY is OK since 5VSTBY is only about 2~3A. You will develop the sense of what you are seeing with the lamp to tell you if something is not quite right, it is hard to explain, but when you do it enough you will understand what you are seeing.
                          If the load requires 100W, then you will need to figure out what the series resistance should be so you will still get to within 10% of the running voltage on the load. When the lamp is fully lit due to short, the voltage on the load will be very small.
                          • neuron
                            • Feb 2013
                            • 126
                            • Portugal
                            What other "guns" you have in your Lab.?
                            Best regards,
                            Ruy
                              Old CFL for inveter tester:
                              http://s807.photobucket.com/user/bud...?sort=3&page=1
                              • neuron
                                • Feb 2013
                                • 126
                                • Portugal
                                Please instructions
                                • ezenia
                                  LUMIMAN Smart Bulb IC ID?
                                  by ezenia
                                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                  04-28-2025, 05:56 PM
                                  Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                  I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                  I also have back when Light of America had these light bulbs available for yard lights
                                  The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                  While the Lithonia lighting fixture has all most certain bulb failure
                                  So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                  I have only had this light fixture for not more than a year if it...
                                  07-02-2023, 03:45 PM
                                  Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                  12-14-2023, 07:45 PM
                                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                  LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 09:10 PM
